Any chance for a pic or 2 of the backside showing racking/supports ?
10.4 KWh DIY Ground Mount Finally Online
Can you post a picture of the back? My self installed 10.8KW Unirac system is set in almost 5 yards of concrete. The 2.6 yds sounds a bit light, but I'm sure that it meets spec.You do not have permission to view this gallery.
This gallery has 3 photos.Jeff, BSEE, 22.3KW, 45-240W w/M190, 46-260W w/M250Comment
Another nice installation.
Did you do anything to reduce the amount of shade coming from those trees to the left of the array?Comment
Nice installation jorgey!
Those look like pretty long spans for your vertical pipes.
I think that the picture is a little deceiving, it is all within IronRidge's specs and the pipes are 3" galvanized steel.Comment
Here is a picture that I took 10 days ago of the backside. The picture is after a snow storm and I had just finished brushing off the panels. When I was done, I checked the SolarEdge app on my phone and was surprised that it was already generating over 3Kw with very little sun coming through. (You can see the sun just starting to peak through all of the clouds.)
The structure itself is 3" galvanized steel with IronRidge diagonal bracing, mounting hardware and XR1000 rails.
Although not needed and not called for in the plans, I installed a disconnect for each string at the array. If I have to do some maintenance, I can shut down only half of the array at a time and still keep generating.
This gallery has 3 photos.Comment
Very nice.
It looks like you used 2" pipe, is that correct? If I would have used 2" that would have doubled the number of piers and I would have then used about 5 1/4 yards of concrete. (Similar to your setup.) When I decided to go with the 3" pipe I was only thinking about the strength and having to drill less holes and have less piers. I wish I would have thought about how heavy the pipe would be. It was a beast!Comment
Looks like a bombproof professional installation. Nice job!
Where are you located? Looks like Colorado front range.Comment
Yes, trimmed back the Maple tree, but right now there are no leaves and the sun is low! There's an oak tree to the right that's coming down soon. Also, I'll be getting a large construction lift in the spring to paint my house. That will make the tree trimming a breeze!Jeff, BSEE, 22.3KW, 45-240W w/M190, 46-260W w/M250Comment
Yes, the Unirac LA setup only uses 2" schedule 40 pipe. For the legs I drilled and tapped using a 7/16" X 3" galvanized bolt to anchor them.
Very nice.
It looks like you used 2" pipe, is that correct? If I would have used 2" that would have doubled the number of piers and I would have then used about 5 1/4 yards of concrete. (Similar to your setup.) When I decided to go with the 3" pipe I was only thinking about the strength and having to drill less holes and have less piers. I wish I would have thought about how heavy the pipe would be. It was a beast!Jeff, BSEE, 22.3KW, 45-240W w/M190, 46-260W w/M250Comment
Great job.
It appears that you created a ground ring around the array since you stated that you installed four ground rods. My only question is why you spiraled the GEC around the outside posts instead of a straight and short route to the rods?Comment
The problem with trimming, is in a couple years the tree is right back at the same height, if not as dense. The significant other says
I might as well just cut them down (which doesn't require hiring any equipment), so that is what I will do. Bruce RoeComment
I love trees - to my south.Comment
