Would you buy if offered Battery Bank?
LOL and thank you. How many years did it take for you to be so stupid?
MSEE, PEComment
Now we know you are a liar. There is no such thing as a certified electrician. What ever technician certificates you may or may not hold are worthless pieces of paper.
To be an Electrician requires a License. If you were a Sparky, you would know that.MSEE, PEComment
May I direct you to http://www.dir.ca.gov/dlse/ecu/electricaltrade.html which says
Electrician Certification Program
Existing law requires that persons performing work as electrician under a C-10 licensed contractor be certified..."
The whole context of the law is :
In english it says "If a C-10 contractor does not hire a licensed electrical contractor, he can put his C-10 lic on the line and hire a person who is merely "certified"..Existing law requires that persons performing work as electrician under a C-10 licensed contractor be certified pursuant to certification standards established by the Division of Labor Standards Enforcement. “Electricians” is defined as all persons who engage in the connection of electrical devices for electrical contractors licensed pursuant to Section 7058 of the Business and Profession Code, specifically, contractors classified as electrical contractors in the Contractors State License Board Rules and Regulations [Labor Code § 108 (c)].
But Certified cannot work a job by themselves, they have to work under a Licensed contractor who is supposed to supervise them.
In the interest of civility and accuracy, though, do you agree that it was incorrect for anyone to claim there's not such thing as a certified electrician?The whole context of the law is :
But Certified cannot work a job by themselves, they have to work under a Licensed contractor who is supposed to supervise them.Comment
Screw civility. At this point, seems more of a legal question than one of politeness/civility. If so, and if I had any remaining concerns about accuracy, I'd consult an attorney knowledgeable in such areas for a legal opinion about the meaning of the section of the legal code as quoted, and call it done/stick a fork in it.Comment
Comic sans or no, saying "screw civility" is probably not good for the tone of the board.Screw civility. At this point, seems more of a legal question than one of politeness/civility. If so, and if I had any remaining concerns about accuracy, I'd consult an attorney knowledgeable in such areas for a legal opinion about the meaning of the section of the legal code as quoted, and call it done/stick a fork in it.
All I'm saying, is it sure looks like you can get certified as an electrician in California, and there are even jobs advertised for certified electricians ( http://www.indeed.com/q-Certified-El...rnia-jobs.html ). I think SK owes the OP an apology, in the interest of civility.
I'm not saying SK should back down -- just saying it's good form to acknowledge it when you say something factually wrong (e.g. "There is no such thing as a certified electrician"). But I understand that acknowledging one's misstatements might not fit in with the scorched-earth style of debate popular with some here.Last edited by DanKegel; 07-09-2016, 03:36 PM.Comment
This is so annoying, but I'm not going to look up "Section 7058" to see exactly who is what. And that will vary from state to state.
The point is Certified is not the same as being Licensed, which is a higher standard.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
As usual, take what you want, or in this case, lighten up and appreciate the attempt at some ironic humor. Scrap the rest. (or put it where the sun don't shine
I was curious if the OP would like to share the recipe of that mighty battery that can be guaranteed for 15 years ...Comment
My guess is that it would have to be Lithium based chemistry or the OP would not be able to claim a discharge down to 20%. Also since a cooling system was mentioned again Lithium chemistry comes to mind.
As for lasting 15 years. Well the jury is still out on that matter.Comment
Comic sans is our way of being sarcastic. Even I have made statements that could be considered demeaning but I was trying to be funny.
I don't care much for being politically correct.Comment
