Floating solar water pool pump
  • Ronthebeginner!
    • May 2024
    Thank you for your time in advance. I am building a floating solar water pool pump and want to know how I can prevent electrocution if someone does not remove it.
    The optimal answer is to remove it from the water before swimming but I am at work all day and the world is full of mysteries.
    Any and all ideas are appreciated. Thank You
  • michaelmend
    • Nov 2025
    • 3
    I think if the entire pump system—including the motor—is powered by:
    ≤ 12–24V DC
    then the risk of dangerous shock in water is drastically reduced.
    Commercial “solar pool circulators” use:
    - Brushless DC pumps (BLDC) at 12–24V
    - No AC components anywhere near the water
    This is the single biggest safety difference.
    • adrianfen45
      • Oct 2026
      • 11
      The low-voltage DC point is the one I keep coming back to, but even 12–24V needs a sealed, potted motor and waterproof glands, or a flooded connector is still a problem. I have a small above-ground pool here in Baton Rouge and want a floating circulator I can leave in during the day, but I am unsure whether a fused line at the panel and an RCD on the panel side adds enough margin if the float tips. I came across <link removed> while looking at options. Anyone running a DC setup through a full summer?
      • azdave
        • Oct 2014
        • 811
        Originally posted by adrianfen45
        The low-voltage DC point is the one I keep coming back to...
        Can we please just ban this account? They are clearly only here to sneak in advertising links.
        Dave W. Gilbert AZ
        6.63kW grid-tie owner
          • 15211
          i have removed the link to the pool cleaner site if it comes back i will ban the poster
          By the way azdave you have the ability to ban the poster
          • sdold
            • Jun 2014
            • 1497
            He added that link after I warned him about another one, so I'll ban him.
            • rustycloe
              • Apr 2026
              • 5
              I would be very cautious with a homemade solar-powered pump around swimmers. My first recommendation would be to use a certified extra-low-voltage DC pump with an isolated power supply and keep all batteries, controllers, and electrical connections well away from the water. Whether it's a homemade setup or a diamond swimming pool, electrical safety should always be the top priority. A properly installed GFCI/RCD protection system is also important, but it shouldn't be the only safety measure. You could also consider an automatic power cutoff linked to pool access. However, I wouldn't rely on a DIY sensor as the main protection. Have the entire setup inspected by a qualified electrician, and make sure the pump is completely disconnected and removed before anyone swims. Safety is definitely worth more than the convenience of leaving it running unattended.
              • sdold
                • Jun 2014
                • 1497
                Originally posted by rustycloe
                I would be very cautious ...
                Hey, just curious, did you ever get your bird problem solved? The one where they were nesting under your rooftop array?
                • ZhangSheng
                  • Nov 2026
                  • 7
                  A couple of wiring points that matter as much as the voltage choice:
                  Keep the whole system low-voltage DC — a 12–24V brushless DC pump with the panel and controller on dry land, and no AC anywhere near the water. Then treat the cable run as the weak point: use one continuous length of submersible-rated pump cable from the motor to the shore, with no splices in or under the water. Make the connection in a weatherproof junction box above the waterline, with proper cable glands and strain relief, so a tug on the cable never pulls on the terminals.
                  Two things that often get missed on these builds: first, voltage drop — a long, thin cable run can starve a 12V pump, so size the conductors for the actual run length and the pump's maximum draw, and fuse the circuit at the panel/controller end. Second, chafe: secure the cable where it crosses the pool edge or coping, because a nicked sheath in pool water is how a safe low-voltage setup turns into a fault. If the cable does get damaged, replace the whole run rather than taping a joint and dropping it back in the water.
                  And as rustycloe said, any AC side of the setup (charger, mains supply) should be on GFCI/RCD protection. A quick insulation check of the pump cable before the swimming season is cheap insurance.
