Floating solar water pool pump
  • Ronthebeginner!
    • May 2024
    Thank you for your time in advance. I am building a floating solar water pool pump and want to know how I can prevent electrocution if someone does not remove it.
    The optimal answer is to remove it from the water before swimming but I am at work all day and the world is full of mysteries.
    Any and all ideas are appreciated. Thank You
  • michaelmend
    • Nov 2025
    • 3
    I think if the entire pump system—including the motor—is powered by:
    ≤ 12–24V DC
    then the risk of dangerous shock in water is drastically reduced.
    Commercial “solar pool circulators” use:
    - Brushless DC pumps (BLDC) at 12–24V
    - No AC components anywhere near the water
    This is the single biggest safety difference.
    • adrianfen45
      • Oct 2026
      • 11
      The low-voltage DC point is the one I keep coming back to, but even 12–24V needs a sealed, potted motor and waterproof glands, or a flooded connector is still a problem. I have a small above-ground pool here in Baton Rouge and want a floating circulator I can leave in during the day, but I am unsure whether a fused line at the panel and an RCD on the panel side adds enough margin if the float tips. I came across Best Pool Cleaners of 2026 pool while looking at options. Anyone running a DC setup through a full summer?
      • azdave
        • Oct 2014
        • 811
        Originally posted by adrianfen45
        The low-voltage DC point is the one I keep coming back to...
        Can we please just ban this account? They are clearly only here to sneak in advertising links.
        Dave W. Gilbert AZ
        6.63kW grid-tie owner
          • 15211
          i have removed the link to the pool cleaner site if it comes back i will ban the poster
          By the way azdave you have the ability to ban the poster
          • sdold
            • Jun 2014
            • 1496
            He added that link after I warned him about another one, so I'll ban him.
            • rustycloe
              • Apr 2026
              • 5
              I would be very cautious with a homemade solar-powered pump around swimmers. My first recommendation would be to use a certified extra-low-voltage DC pump with an isolated power supply and keep all batteries, controllers, and electrical connections well away from the water. Whether it's a homemade setup or a diamond swimming pool, electrical safety should always be the top priority. A properly installed GFCI/RCD protection system is also important, but it shouldn't be the only safety measure. You could also consider an automatic power cutoff linked to pool access. However, I wouldn't rely on a DIY sensor as the main protection. Have the entire setup inspected by a qualified electrician, and make sure the pump is completely disconnected and removed before anyone swims. Safety is definitely worth more than the convenience of leaving it running unattended.
