I remember the guy setting the cylinder on a scale and filling from a larger bullet - might be different for automotive use now
Fridge / freezers
Russ thats how they do it with cylinders ,The tare weight is stamped on the cylinder and they just stop when it gets to tare +15 KG.
For LPG in vehicles you either stop at some point you decide or fill until back pressure stops the flow.Comment
For home tanks like my 550 gallon unit, and I would assume for vehicles they use a float type gauge just like a regular vehicle would use for a liquid fuel.MSEE, PEComment
And they stop when the container reaches about 80% capacity. My 1000 gallon tank only ever gets filled to 800 gallons.NABCEP certified Technical Sales Professional
In the US, by law portable refillable LPG containers and residential stationary tanks must have an internal "dip tube" used as a vent when filling, and when the liquid inside the tank reaches the open bottom of the tube liquid starts coming from the vent and you know it is time to stop pumping.
Recently, as a "safety measure" LPG suppliers who exchange full tanks for empty ones have reduced the standard fill level, but kept the exchange price the same.
20 years back I was organizing safety instruction for a bunch of part timers for a test campaign we were running - to do with hydrogen and CO production. One film was called BLEVE (boiling liquid, evaporating vapor explosion). Rather vivid examples of what happens when a LPG bullet blows - it tends to clear out the surrounding area with the diameter set by the volume of the bullet.
One part was somewhere in the SW where firemen were trying to extinguish flames from one bullet when the second one besdie the burning one blew. Observers sitting along the road 1/4 mile away were turned into crispy critters. Doubt they found anything of the firemen.[SIGPIC][/SIGPIC]Comment
Was at Stanford when a tank transfer accident caused a large liquid hydrogen leak, which ignited. Fortunately nothing else close. The last thing the firemen wanted to do was extinguish the flame! They concentrated on cooling the outside of the tank (separating it from the flare with a wall of water) until, about 12 hours later, everything had burned off.20 years back I was organizing safety instruction for a bunch of part timers for a test campaign we were running - to do with hydrogen and CO production. One film was called BLEVE (boiling liquid, evaporating vapor explosion). Rather vivid examples of what happens when a LPG bullet blows - it tends to clear out the surrounding area with the diameter set by the volume of the bullet.
One part was somewhere in the SW where firemen were trying to extinguish flames from one bullet when the second one besdie the burning one blew. Observers sitting along the road 1/4 mile away were turned into crispy critters. Doubt they found anything of the firemen.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Wow, we're paying closer to $4/gal for LPG here.
So, several places on the net I've seen the statement that new, high-efficiency 120V fridges are so efficient now that they're about the same energy usage (via an inverter) as just buying a specialty 24V DC fridge. Is there any truth to this? On the one hand, I'd expect specialty built off-grid fridges to be the most efficient thing out there. On the other hand, energy usage is something appliances now compete on in big box stores, and that usually drives innovation. The specialty manufacturers publish energy consumption charts for inside vs outside temperatures but the 120V ones don't. Anyone have real data for this comparison?Comment
In the desert incident the leaking and burning bullet was manageable - the problem was the second tank that was boiling and ruptured - the expanding vapor cloud acts as an air fuel bomb - very nasty.Was at Stanford when a tank transfer accident caused a large liquid hydrogen leak, which ignited. Fortunately nothing else close. The last thing the firemen wanted to do was extinguish the flame! They concentrated on cooling the outside of the tank (separating it from the flare with a wall of water) until, about 12 hours later, everything had burned off.[SIGPIC][/SIGPIC]Comment
before 1995 vehicles in Australia had the dip tube to tell you when the tank was full but now they have automatic cut off at about 80% full.
90% of all taxis in Aus run on LPG. Its usually half the price of gasoline or here petrol. 75c V $1.50 a litre
But in Philippines they just fill the portable cylinders until the weight is correct. And no one seems to worry much about test dates . all is ok if the tank is nicely repainted before delivery. Appearance is most important.Comment
Like elevator inspections in much of the world - done every 50 years or so - needed or not.[SIGPIC][/SIGPIC]Comment
I'm off grid, and use a Frigidaire 18CF top freezer, and it consumes just over 1KWh per day.Wow, we're paying closer to $4/gal for LPG here.
So, several places on the net I've seen the statement that new, high-efficiency 120V fridges are so efficient now that they're about the same energy usage (via an inverter) as just buying a specialty 24V DC fridge. Is there any truth to this? On the one hand, I'd expect specialty built off-grid fridges to be the most efficient thing out there. On the other hand, energy usage is something appliances now compete on in big box stores, and that usually drives innovation. The specialty manufacturers publish energy consumption charts for inside vs outside temperatures but the 120V ones don't. Anyone have real data for this comparison?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
As I understand it, the problem is being tied to the grid. Something about being dependent. My step-son worked on an Amish farm for awhile and they were all about battery banks, PV panels, and generators.Actually Quakers have not problem with electricity.
The Amish who are the primary users of gas refrigeration and make a good one don't like electricity.
Strange quirk of this religion is that they are allowed to have telephones computers and power tools for use in their business but not in their homes.Comment
