How to increase solar panel output amps
Or, approx. .024 of a square meter. -
As long as we're trying to be clear as well as accurate as possible, "standard" square cells, whatever standard may mean in that context are 156 mm on a side. Many Americans are still thinking in a different measurement system than most of the rest of the world.Leave a comment:
From your page:
"Are new fiber optics solar batteries will not need the Sun,yet will still be connected from a cells to an electrical circuit, Called a charge controller. How many amps of electricity will it produce, depends on the Fiber optics solar batteries what size solar cell are because the fiber optics produce its own light, so they are constant when it comes to light."
So you have fiber optics which produce their own light, and you will use that light to produce energy from solar panels. Maybe you could then use the power you generate to light an incandescent light bulb, then send that light to the fiberoptics, and make more and more energy! Your only problem would then be producing _too_ much free energy from nothing.
To think I was here when this world-changing innovation was first revealed . . . .Leave a comment:
Thank you for that most positive and intelligent answer, so far what we have learned with our experiment, to keep the system balance amps and votes, 99.9 of the sales are the same voltage and amp range. We had to go other places to find out how to turn it into a bigger cell, and you are correct and what you said it coincides what we've been told by others. This system is brand new and we want you to see the very beginning test of what we're doing, of course I don't expect anyone to understand something that hasn't been done before, it's why we are taking our time and doing each experiment to make sure that this system is viable. Does it work absolutely that's not the problem understanding the small little details is what's so frustrating about the system. And what you said about safety yes we've already called a fire amps were too high overheated, so we needed to make electrical buses one for the amps and the other four voltage separate, I'm getting ahead of myself. Let me show you what we're doing first of all email and contact numbers are on the paper, a lot of detail has been left out for a purpose people think you're very stupid if you give them too much information and it's correct they'll be running to the patent office with your work.If you understand the performance of solar cells it is possible to wire an unlimited number of them
in series-parallel combinations to increase energy collected. The general rules are that cells with
the same current rating may be efficient wired in series, and cells with similar voltage ratings may
be efficiently wired in parallel. There are practical considerations such as safe voltages and currents
with proper insulation and over current protection, wiring losses, weather tolerance, and shade.
Practical systems generally simplify the above problems by using the largest cells practical, half
a foot square today, packaged for an outdoor life of decades. Bruce Roe
ghttp://showmeyourproof.blogspot.com/2018/09/fiber-optics-solar-batteries.html
thank you for taking the time to answer AR questionsLeave a comment:
Thank you, cheap is not what we're trying to do here, it's an experiment to see what can be done also a teaching tool for people to understand exactly what parallel and series actually mean. Most people won't tell you that solar cells are just smaller cells within themselves making one big huge cell. Understanding how you got the size sale in the first place is stuff that people normally overlooked when trying to understand solar cells, all the little details are important and what we are asking about. Keep in mind I always keep my promises so I'm sending you the beginning paper on this new technology that we are developing it looks promising, but we are still learning the basics which is hard to learn this my smaller details. Please take a look at what we're designing and leave a comment it doesn't matter if it's positive or negative, it only matters at the end of this experiment what we learn out of it.
Learn about little or no one knows about, things that corporations and governments really don't want you to know because it affects their bottom line.
Ex to U,
the key word is 'Practical'. What you are suggesting is like trying to replace a 5 hp lawnmower engine with five 1 hp engines. It can be done, but even if you already had the five 1 hp engines, it would be cheaper to buy a single 5 hp engine.
--mapmakerLeave a comment:
a foot square today, packaged for an outdoor life of decades. Bruce RoeLeave a comment:
First thing I'm brand new to this message board, don't quite understand how it works so if I posted it twice it was an accident. Second thing you could have just simply said you didn't want to answer the question you didn't have to be so nasty about it to a newbie. Third of all I will report this to whatever Authority that governs these boards is this is the welcome newbies have to endure then it's not worth the effort I'll go elsewhereLeave a comment:
Firstly, I have no idea why you would post the same reply twice. Secondly, I don't care to know about your "secret littke experiment". It sounds as though most of us here have forgotten more than you will ever know about solar energy.
I'm doing a project, to get students to understand solar, but after trying to answer certain questions they had. I had to go looking for a better understanding, so here's the question we have hundreds and literally thousands of cheap solar lights we have taken apart for this project. We want to know if you add enough of these types of solar which doesn't put out very much power is it even possible to run an entire home. And how would you go about wiring them up to make bigger and stronger solar panels. If you answer with a satisfactory answer we will let you know about our secret little experiment, and I think if it's possible to add more solar to get more power even more amps then you're going to love what we're doing here with this new type of Technology made from the cheapest solar cells on the planet. Yes this is a mystery, what can you actually run with such a low powered solar cell and can you increase it to actually do something it was not intended to do, this is experiment to understand(Ex to U)
The correct way to do what you want is to replace your charge controller with an MPPT type of controller. In your case, it will not be cost effective to do so.... it would be cheaper to just buy another solar panel, as 'livingincebu' suggested.
Also, unless your battery is an AGM type battery (which can handle higher charge currents), you already have an adequate charging rate.
Regarding your question about boosting amps... you will never be able to exceed the output watts of your panel. And you will rarely, if ever, get the rated power from your panel. Your panel will produce up to 18 volts and up to 8 amps. 18 volts X 8 amps = 144 watts. That represents the max power possible. Typically, you get about 75% of that.
If you use an electronic device to increase the output current (amps) it will come at the expense of reducing the output voltage. There is no way to get volts X amps to equal more than the 150 watt rating of your panel.
As I mentioned, you could use an MPPT controller to decrease the the input voltage a bit so it better matches the battery voltage. That would give you a corresponding increase in amps to the battery, but it is usually not cost effective to do so in a system as small as yours.
I'm doing a project, to get students to understand solar, but after trying to answer certain questions they had. I had to go looking for a better understanding, so here's the question we have hundreds and literally thousands of cheap solar lights we have taken apart for this project. We want to know if you add enough of these types of solar which doesn't put out very much power is it even possible to run an entire home. And how would you go about wiring them up to make bigger and stronger solar panels. If you answer with a satisfactory answer we will let you know about our secret little experiment, and I think if it's possible to add more solar to get more power even more amps then you're going to love what we're doing here with this new type of Technology made from the cheapest solar cells on the planet. Yes this is a mystery, what can you actually run with such a low powered solar cell and can you increase it to actually do something it was not intended to do, this is experiment to understand(Ex to U)Um, crazy question. Why not just add more panels in parallel if you wish to increase your ampere output from the array?
Of course, if you are going to try to put 18 amperes into a 60AH battery, that is going to be a tad too much. So, you are going to need more AH of storage as well.Leave a comment:
First a 1/5 Kw inverter with a 12 volt 60 AH battery and 150 panel is a huge mismatch and not compatible. Rule of thumb is Panel Wattage = Inverter wattage (or 1:1 ratio) for FLA batteries, and 1:2 ratio for AGM . A 150 watt panel, and a 150 to 300 watt inverter. You are @ 1:10 ratio. No wonder you are having problems
Panels, charge controller, battery, and load device (inverter in your case) all have to be matched up, and the key is the batteries. If using Flooded batteries the maximum current drain is C/8, and C/4 for AGM. So you have a 60 AH battery. That means based on the battery alone if it is FLA can only handle 7.5 amps x 12 volts = 90 watt inverter, or if AGM 180 watts. You have 1500 watts right?
For a 1500 watt inverter really requires 24 volt battery @ 24 volt 500 AH battery, with a 1500 watt panel and 60 amp MPPT controller.
Turn this around based on your 150 watt battery panel the maximum is a 10 amp PWM controller, 12 volt 60 AH FLA battery, and a 100 watt inverter. Or if you used a MPPT controller with a 150 watt panel can support up to a 12 volt 100 AH battery, 15 amp MPPT controller, and a 150 watt inverter.Leave a comment:
The reflector increases the cell heat load and will require cooling - not practical
The tracker is expensive - better to just use a few more panels in the arrayLeave a comment:
