I will try to keep this short.
My home in the winter consumes 61.44KWh day when the heat pump is in use, the break down in 24 hours would be 2.56 KWh . I've modestly rounded out to 2.8KWh, which would be 67.2KWh day.
Concord California Sun Hours are recorded on a modest 5.6 of consistent sun. I am assuming I will need roughly a 12~13KWh array.
5.6 sun hours X DC side 12.3KWh = DC side 68.8KWh DAY
So I selected a panel that when in a string of 2 is suitable for 48V.
SUNTECH 205W 26.3VmP 7.8Imp
26.3VmP X 2 = 52.6VmP
Combined 10 Strings = 78 Imp
So now I would duplicate this 3 times.
Total of 3 sets of arrays
Total of 3 sets of combiner (midnight solar 12, 10-150V breaker/15 amp)
Total of 3 set MPPT outback 150V, 60~80amp
Total of 1 Combiner 3 string
Total of 1 battery bank string of 4 surette 48v, 357Ah (seems to be the best choice recommended by Sunking)
Total of 1 sunny island inverters 4248U
1 pole DC disconnect (fuseable)
1 pole AC Disconnect (visable and fusable)
AC side result should be roughly 54.35KWh DAY.
My fiancee and I realized that we would need to make some cut backs. First one would be to use the heat pump less, or have it removed as the unit itself is 25 years old and isn't efficient.
Now my question is some one with off grid design build will the equipment I want to use for this set up work. Or will I need a higher voltage panel?
Total system $42,404.10
