That's good info, Mike, but it makes me wonder even more, why is the connection to the charge controller so haphazard in comparison? The stranded wire bundle is just pushed into a square hole and held in place by a couple of flat metal sides that get squeezed together like a trash compactor when you turn a screw. That can't be making as good a connection as even a bad crimp job.
8 Gauge to 10 Gauge Wire Reducer?
Because crimps are often hidden, and the controller screws generally visible.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
