Set up problem or full battery?
  • Filter
  • Set up problem or full battery?
    635C06BC-D1ED-43C7-8BC3-1C70182A533C.jpeg I have four Renogy 100 W panels wired in parallel.
    I tested each panel individually, while hooked up to a battery that is 100% full. Each individual panel was giving me 20 V and approximately 2 A
    when I hooked all four together the charge controller was still saying roughly 20 V and roughly 2 A.
    do I have a problem somewhere or is the battery so full that the charge controller is not putting more into it?
  • #2
    First guess, is the battery is full.
    Question "charge controller was still saying roughly 20 V and roughly 2 A."
    When you measure the 20V, is that at the battery or the PV panel ? The 2 amps, at the panel or the battery ?
    • #3
      Those numbers are all coming from the charge controller. How can I figure out the amps on a solar panel with a multimeter?
      • #4
        Is the 20V the panel voltage or the battery voltage ? The controller manual should state how to display specific values
        • #5
          I found another battery and hook it up. Then I was getting 19 V and 18 A which makes sense.
          Thank you for your advice on the battery.
          • #6
            Hopefully that battery is rated around 200Ah. If it is less than 150Ah those 18 charging amps can cook it.
            • #7
              Is the 19V the voltage of the panel, or the battery?
              • #8
                170Ah Lithium. For what it
                is worth The manufacture says maximum charging is 50 A.
                • #9
                  I believe that is the panel.
                  • #10
                    I believe you might be right . or you might be wrong. I don't care. I'm an engineer and I deal in facts. You can believe the fuse is not lit, but the dynamite won't care what you believe.
                    I believe the fire is out, and it's OK to fill the gas tank. Do you get what I mean ?
                    I believe the lane next to me is empty . Whoops.
