I NEVER use the current scale on multi meters. I put some kind of shunt in the circuit, or use
a clamp on meter. No interrupting circuit operation, and no smoke. Bruce Roe
Parallel panel amperage problems?
If there is no current reading when the meter probe is plugged into the 10A jack, most likely there is a blown 10A fuse inside the meter (probably inside the battery case for easy access).
You also probably need to manually set the meter to the 10A range instead of depending on autoranging.Last edited by inetdog; 02-12-2019, 04:02 AM.Leave a comment:
Sdold,
They are Panasonic 330w panels, VBHN330SA16
Thank you for your helpLeave a comment:
They only produce power during the day, primarily at mid day. You might see some voltage under low light conditions, but little or no current will be produced. Try it tomorrow around noon. In fact it would be educational to connect the ammeter early in the morning, and watch the value rise as the day progresses. You'll see how little current is produced in the early morning, and how you really get the majority of the current closer to noon. It's OK to parallel the panels for this as long as the sum doesn't exceed 10 amps.Last edited by sdold; 02-12-2019, 01:29 AM.Leave a comment:
Sdold,
No it's night time. The pictures I took above were at night. We have alot of light pollution here so I still get some readings.Leave a comment:
Sdold,
I did what you suggested but received no reading.
Sorry if I'm fumbling this guy's.Leave a comment:
Inetdog,
Sorry I meant to specify that it was suggested to take a reading while the system, not circuit was completed with a charge controller and battery but I'm still wondering is if I'm going crazy or not if I m correct in saying that readings direct from the panel while in parallel should be a combination reading of the two?Leave a comment:
Plug your red test probe into the 10A jack, it looks like you have it in the V jack.Leave a comment:
How can there be any current flow on an open circuit? Did someone co opt Ohm's law? When one connects Amp meter leads to a source without a load, one creates a short circuit, correct? Is that what inetdog was asking?
By definition, you cannot have current in an open circuit. The current has to flow somewhere. The question is whether you are using something as a load (problem!) or connecting the panel terminals directly to the two terminals of the ammeter (measuring what could be called the short circuit current, symbolized by IMAX.
If you are measuring voltage and current at the same time you do not have either an open circuit or a short circuit.Leave a comment:
Inetdog,
I'm just currently testing the panels themselves. I was just curious if the no increase in amperage while connected in parallel was a result to me taking the readings as an open circuit and if completing the circuit would result in the correct amperageLeave a comment:
