I changed out some led lights to run off dc solar. You need a dc-dc driver for whatever leds you have. Here is what I found to work. They should have something that will do what you want.
solar system for shed
Sorry, I didn't know you had 12VDC at the shed. So using a buck or linear voltage regulator to drop the voltage, and then use a LED driver circuit to limit the amps (LED will gleefully suck all the amps they can and burn out in an instant)
Or you can simply buy some 12VDC RV lighting, or roll your own with LED bulbs with integral drivers for 9-30V like these:
https://www.wiredco.com/10-LED-SMT-S...olwhiteled.htmLeave a comment:
Not 120v my shed runs off of a 12v battery. So it’s 12v dc to 1.5v dc.
ive seen voltage regulators that are cheap and go from 1.5-3-6-9v and so on. Couldn’t I just do that?Leave a comment:
simply, NO...
so my question is can I run these battery powered solar lights off of my shed solar system? I know the voltage for the aa battery’s is 1.5 and lithium is 3, I believe these lights use the 1.5 v. Is there any way I can solder the positive and negative of each light together and run it to my fuse box? Maybe add a resister in the line?
thank you all again for the responses
No safe or sane way to connect a solar light to 120VAC
Why not use a regular LED night light that's designed for 120VAC and bypass the fireworks.
I have a question and it might be stupid or a really easy answer but I just bought some led outdoor lights that have a small solar panel on them that charge a double a battery.
I read a post on this forum where someone wanted to run their lights off of solar everyday and the system would cost a lot of money for that.
I don’t want to run mine everyday just whenever I’m in the shed I want to turn them on. I know they sell wired 12v outdoor lights but they are really expensive in comparison to what I paid for these.
thank you all again for the responsesLeave a comment:
Well a battery that small might be charged with a small wattage panel but they are Lithium chemistry type batteries and will require a proper charger.
The only way I see it working is for you to use an inverter with a 5-6v output connection but they probably need a 12v battery to connect to first and you will need to get a 12V PWM solar charger that works with a larger pv panel.Leave a comment:
12000mah so 12ah? They get charged with a dc Input at the side of them which accepts 5-6v and 2a max. And I have two of themLeave a comment:
But what is the Ah rating of those V44 batteries and how are they supposed to be charged?Leave a comment:
I actually just figured it out... I could run the solar panel wording to the battery and right beside the battery have a cc with dual usbs out and connect each one to these battery’s.Leave a comment:
I should of gave the information on which battery’s I have I have the voltaic v44 they’re small battery’s you put into your pocket as a spare.
I didnt know if i could charge both of them with a 12v panel.Leave a comment:
Well to charge a 12v battery system you need about 17volts. Most "battery" 12V panels really deliver between 17 & 18volts but to keep a set of FLA batteries properly charged you need about 1/10th the Ah rating. So if your two 6V batteries create a 12V 200Ah battery system you would need about 20amps to charge them.I have two 6v batteries but they are connected using a dc connection and have usb outs. I can’t open it and play around with them they are just a extra battery when I go camping.
I have it it hooked up to a 6v solar panel but it’s not really doing a good job in the winter time charging both of them.
what I would like to do is buy a 50 watt or 25watt 12v panel and charge my two 6v battery’s. I’m wondering if there is something that I can buy to change the voltage from a single 12 to 2 6vs?
So that 6V panel is just about useless for your batteries and even a 50watt panel will not do the trick. For 20amps you would need about 240watts and a MPPT type CC or 4 panels that can delivery more than 5 amps each wired in parallel to a PWM type CC that is rated 20 to 30amps.
Building a solar/battery system is not necessarily cheap.Leave a comment:
what I would like to do is buy a 50 watt or 25watt 12v panel and charge my two 6v battery’s. I’m wondering if there is something that I can buy to change the voltage from a single 12 to 2 6vs?Leave a comment:
It’s a lead acid deep cycleLeave a comment:
It may depend on the chemistry. I used a battery tender on a pick up truck that had a weak lead acid battery and it kept it topped up because the truck, like most modern vehicles, had vampire loads and was not driven enough to stay charged.I know with battery’s they have a c rating for charging and discharging. What I’m wondering is what does everything think about hooking up a battery tender on my 4 wheeler? It pulls half a amp or 1 amp and I know that way below the c ratings of my battery.
what do you guys think?Leave a comment:
I have a 75 ah deep cycle battery and would like to connect my battery tender to it but want to make sure I’m not messing up the battery slowly.
The shed dosent get used much in the winter time so it would be pretty much only this taking power.
