Tiny House Solar, Wiring Inverter to AC Electric
Before the dogs of safety are unleashed on you, why does everyone go lean on panels. 2x 100 watt panels is a joke and major mistake. Grid tie panels are cheaper than battery versions. Panels are the cheapest thing you will buy. You need at least 1KW to live successfully. OK, I warned you and you are doomed to make the same mistakes as any beginner. -
I've built a tiny house and have 2 AC electric lines running in it. 1 for 2 led lights and 1 line for 3 receptacles.
I plant on running a 200w (2x 100watt panels) to a charge controller, to a two battery bank, to an inverter.
My issue is what is a safe way to wire the DC inverter to the AC system?
Is it necessary to have a breaker box for this minimal a system?
Can I go from a GFCI outlet on the inverter with an extension cord to a junction box with the 2 AC lines, instead?
