Well as far as ebay here, there are only 2 sellers I am looking at, and they have thousands of positive feedback, so I'm not worried about that. But like I was saying about sunelec.com prices, if I want a 5kw system that I know the panels are going to last basically forever, I'd buy from there instead of building dozens of panels using glass of thick polycarbonate and only saving a small percentage. I'll probably just build some to use recreationally and for emergency use. Probably around 1-2kw.
DIY Solar Panels...What kind of glass?
wonderful info!
stumbled onto this thread googling for glass info for building a drain-back waterheater system i'm researching. thanks much--life just got easier!Comment
so sun just a recap you would spend more money on polycaronate glass b/c you will not lose as much power, is 10 % really that much if you are talking 100 dollars or so more for glass??
just a question i hope im not like sounding like im yelling or anything.Comment
Thanks Russ- I guess I was just picking up from the OP question: What glass is best, or rather most reasonable?
Super-exotic glass (Ruby or something?) doesn't seem to be justifiable due to high cost
Tempered
Thickness? Assuming tempered, would one shoot for 1/8" thick total? Too thin?
Iron-Free seems universally desired.
Textured on front for less reflection / more penetration? I guess this has been independently verified hundreds of times that it's much better than flat floated glass?Comment
textured surface? What commercial mfg uses that?Tempered if you want panels to last past the first hail storm then yes
Thickness? Assuming tempered, would one shoot for 1/8" thick total? Too thin? too thin
Iron-Free seems universally desired. less light loss
Textured on front for less reflection / more penetration? I guess this has been independently verified hundreds of times that it's much better than flat floated glass?[SIGPIC][/SIGPIC]Comment
