legionsolar out of San Jose figures out plug and play.
I don't expect to get that answer on this forum or any where else because I believe the answer is that there is no ability for the POCOs to regulate what I do behind the meter. I do think, as that knowledge becomes more widely shared, more people will install generators and battery backups partly stimulated by the recent power outages. Load departure will continue. That is what happened in Hawaii. I would not want to be a shareholder of a utility in California.
In the meantime I will continue to enjoy the benefits of having a backup during power outages and a source of additional energy so all my grid tie generaton will get credited to my account.Last edited by Ampster; 11-10-2019, 12:55 PM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
If you pull the meter, or disconnect with an approved transfer switch, you can do as you please and the PoCo won't care.
Or just go ahead with your plans of whatever and see what happens...
BTW, I checked and in some states only a licensed electrician can pull a meter. There are 240 Volt un fused connectors back there.Last edited by Ampster; 11-10-2019, 03:43 PM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
It was a poor attempt at humor since @SunEagle earlier in the thread said that the Florida utilities were regularly monitoring users consumption. I don't have a problem to solve, but Mike sure thinks I do because I did not ask PG & E for permission to install a UL certified Hybrid inverter. That inverter does not backfeed the grid. I did pull a building permit.Last edited by Ampster; 11-10-2019, 11:00 PM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
This is the big deal from my perspective. Plug-in grid tie inverters have an unsolvable safety problem. (I think it's what sank Orison's product.) You can wire it directly to a branch circuit, of course - which is the right way to do it. But then it needs to have that UL certification.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
