Hey, that looks cold, here is where I am, it's the link to my hostel.
My tiny project in sunny Ecuador
This is a sticky topic.
That was a picture of my front walk with snow. Sorry it didn't come out very good.
Well, I'll give you a Merry Christmas today. Click on the picture and it will enlarge.
WayneLeave a comment:
Wow, is that the panel?
Now I understand why you folks are so worried about insulation of the panels.
Today was very hot, no xmas feelings for a german in the tropics.
I think about you in the nice warm weather and I have a picture to show you .It got up to 11 degrees to day and the solar panels put out 18 volts . that is good but it was short. It's -11 degrees now and starting to get dark.Attached FilesLeave a comment:
I thought someone would have one . Thats the only way to go.Leave a comment:
I thought some one would be doing that.
I have a picture for you. It's just outside my house today . 10 Degrees out.
DC Pump
I'm using such one, it starts to work at 7V and needs only 6W (cost about 30$, shipping included), as I said, I'll make a special mini panel with 2x3 cells purchased from Fred480V.
Those cells aren't broken, they are laser cut.
The pump will not need a timer as it will work only during the day when we have enough light.
I hear that they have solar powered pumps alsoLeave a comment:
@nettech - 'with a 1 gpm pump running'
That comes to about 225 liters per hour - a good store bought panel (flat plate) may put out 200 liters per day of 120 deg F hot water in the winter with real good sun.
Your problem is a very big mismatch between supply and consumption.Leave a comment:
Hi Jeff, thanks for posting your experience.
I'll use the hot water only for the showers and would be fine with 150F (65.6C) about.
You will raise the temperature if you work with copper sheet and solder the tubes to it, the temp conduction will be much better.
Your panel is bigger (1 foot = 30.48 cm) but I plan to use two of them.
I always will have the advantage of the location right under the ecuator and the results will be better, also the outside temp almost never go below 25C (77F).
Joe
Ecosolar, your thumbnail picture of the panel is similiar to my idea/panel (mine failed, my standards). I'm not familiar with metric dimensions, but I think we are close to same size (5'x2'). I used 80 foot of copper tubing (rolled) 3 separate rolls, inter-connected., side-by-side. The copper tubing rested on aluminum facia (lits cheaper than copper sheet), painted black. My panel was enclosed (your picture appears to be open) with 1/2" foam on the back, with plexiglass glazing.
I don't know what you intend to use the hot water for. I wanted to use it for radiant heat. My panel failed to produced sustained 'hot enough' water, with a 1 gpm pump running. The hottest recorded temperature was 150 degrees though.
It will be interesting if your project works for you.
Good luck
JeffLeave a comment:
Good luck
Yeah Mike this isn't difficult at all, three years ago I used an old Chevi air condition radiator to heat up water in the fields, it took one can of black spray, some hoses and about an hour to go.
This will be a little more nice and maybe efficient.
If you know anyone that welds, you could use a aluminum back sheet, it wont last forever, but it woudl be a good proof of concept. Heck, get yourself 2 coils of aluminum refrigation tubeing, and weld/braze that to a alum back sheet. A spray mist of hi-temp flat BBQ black. All done.Leave a comment:
Your project will be very interesting. It will be real nice to see it when you get done.Leave a comment:
Thanks Wayne, but it's made only in Paint.
The Coral Draw is too complicated yet for me.
I simulated this panels with 10m of 3/8 black water hose (pro irrigation hose)in plain sun and it made me +2.8 C each round, I mean from entry to exit.
It will be feeded by a 12V 6l/min hot water pump which works on only 6W and a special solar panel generating 12V/1A, the cells (2X3) are also on the way.
As heat collector tanks I will use 3 50l stainless steel beer barrels which will be isulated twice.
I'l upload pictures when ready but I still miss the coppersheet to start.
