Jesses DIY panel
  • mdmiller1
    • Jul 2010
    • 11
    #31
    The solder is kester electronic. I cut the heat and sped up the speed of my iron sweep across the trace, and voila, no warp.
    Please, there are no gobs, my dad was a ham and I soldered my first radio when I was 4. This is my first adventure with solar, so I'm learning the nuances.
    thanks for the tip ! !
    • hemi
      • Sep 2010
      dow corning
      I came across some dowcorning silcone in the hardware store, it was electrical grade and non corrosive, it also can handle high temperatures and UV etc.
      i have searched the dow corning sight but cant find a product that meet all those needs. anyone got a specific product #?
      • DeltaFox 25
        • Oct 2009
        • 315
        #33
        If this comes out right there are some dowcorning products
        • hemi
          • Sep 2010
          thanks deltafox ive enjoyed your input on this thread.
          im looking for a cheaper solution than slygard. jestronix has mentioned using electrical grade silicone after reading all the silicone product descriptions, icant find a product that meets all of the characteristics.
          ps. what is the diference between the slygard product line they have all of the same characteristics but there reomended uses differ?
          • jestronix
            • Nov 2009
            • 41
            #35
            Hi Hemi,
            So far I havent had any trouble with the electrical grade stuff, as it says its designed for electricals equipment and stands high temp and UV. Perfect for solar panels. So far the cells that I totally coated from the back are fine, but hey only one year in so far. There is one of my panels showing some issues, but this one I simply painted the back with a weather proof paint, i dont think the cells liked something in the paint.
            • Jason
              Administrator
              • Dec 2008
              • 990
              #36
              Hi Jestronix,
              How are your panels holding up?
              • Dominic
                • Dec 2010
                Upside down panel
                Hi all.
                New here, but great site. I have followed all the encapsulation threads and was wondering why not build them the other way round. I was thinking of trying this;
                Sheet of 3mm plastic with tile spacers glued at appropriate places, tab the back of the cells first, lay them onto the plastic sheet on a bed of either sylgard 184 or to save money, a polymer sealant such as Tech 7, let that set and tab the front of the cells (haven't figured which way to do the bus tabbing yet but that shouldn't present too much of a problem!!). Lay masking tape around the plastic panel curled up at the edges to form a tray. Then pour the sylgard over the cells (Blue part is facing up of course) and lay the glass on top to seal the whole lot.
                Any ideas on this? I'm not sure when they're done the other way round that the sealant gets to really seal the face of the cell which I would have thought would be more important than the back.
                • elkowalski
                  • Jan 2011
                  • 32
                  #38
                  hey jeese, what kind of silicone did you use? did you used a brush to spread it?
                  hows the panel doing? i used an elastomer as back sealant and is doing pretty good.
                  • jestronix
                    • Nov 2009
                    • 41
                    #39
                    Panels are still holding up well, I checked them at xmas, still going strong, no moisture or corrosion yet. Only one of the panels has slight blemish around the cells, however this happened in the first week after making them and have stayed that way, power seems fine out of that panel still.
                    Plans for two more in the coming weeks, have some sylgard still in its container, so might put that to use.
                    • opqa
                      • Mar 2011
                      About the silicone
                      I've been searching on a famous online electronic components store and found this silicone, it's just cheap and it has some interesting propierties:
                      Plastic & Glass Silicone Sealant
                      A one part, clear, neutral curing silicone sealant for use in glazing and cladding applications and for perimeter pointing of door and window frames.
                      Excellent adhesion to porous and non-porous substrates
                      Excellent adhesion to polycarbonate
                      Fast cure tack free in 2 hours
                      Excellent weathering characteristics, including resistance to ozone & UV
                      Joint movement capability
                      • electricsuperduty
                        • Jun 2011
                        • 76
                        #41
                        Originally posted by jestronix
                        Hi everyone,
                        Well after lots of reading and dreaming I finally put together a DIY solar panel. Ive been facinated about solar since I was a kid, my parents have run their house on solar for almost 30 years. Their failful old BP 40w module still puts out 2 amps after 30 years.
                        After looking at a few DIY guides, I wasnt too impressed about the plywood designs, whilst they might work I have my doubts about them even lasting 5 years. So after hunting around some more I can across a site in Nicaragua, they use silcone (sylgard) to ecapsulate their cells. Then I found a few videos on youtube also. This looked like a much better way of weather proofing the cells. Also a lot of the earlier panels were made this way, some lasting 30 years plus.
                        So I orderd some evergreen string cells, and got to work.
                        However I whilst I orded the sylgard, it took weeks to arrive, in the meantime I was getting bits like glass and frame together in preperation. I came across some dowcorning silcone in the hardware store, it was electrical grade and non corrosive, it also can handle high temperatures and UV etc.
                        I came up with the idea of laying down the cells on the glass, then simply using the silicone caulk to seal the cells down. I completely sealed the cells with it, it came out $60 cheaper then sylgard (postage is $35). The result is I have the cells totally sealed in a similar silicone to sylgard, there is no worry about the caulk blocking the sunlight as its only on the sides and behind the cells. There are no bubbles infront of the cells either, a common problem with sylgard.
                        I was very suprised with the results of the panel, its putting out 3.7 amps and 20.5 volts. This drops to about 3.5 and 19 volts in scorching heat, lying flat on the ground also so no ventilation under the panel doesnt help. So its pretty close to a factory built 60w panel.
                        As you can see like anyone who has never handled solar cells before, i managed to chip some, unfortunately this effects all cells in the panel and drops the amps down a smidgen.
                        I have left the panel outside for a few weeks, through a storm and rain, minor hail. I even left it on wet grass in the sun for a few days, the back of the panel was soaked, but not one bit of moisture got into the cells. So im happy so far. I have chosen 5mm glass, after speaking to a guy that sold a lot of glass to a caravan park that used 5mm glass for their hotwater panels, he said they have been through heaps of hail storms with no worries.
                        Ive managed to pick up 5 second hand glass sheets for $3 a sheet 8mm shelving glass, i suspect its tempered, all up Ive worked out I can build the panels for about $140.
                        cell sealed with silcone.
                        I have plans to use one for camping etc and give the rest to my parents for now, they are cheap to make, and Ill be keen to see how they last over time, most of all I get a buzz outta of it !!
                        being my first panel, it took a lot longer then I thought, next one should be easier.
                        Im also looking into sealing the cells, then laying down a plastic cover sheet on the back of the cells, this will reduce the need for so much silcone and reduce time and costs. Its just an idea at this stage.
                        How did you spread the silicone out?
                          Good work. your results are one of the few better thought out ones.
                          • jestronix
                            • Nov 2009
                            • 41
                            #43
                            2 years no leaks !!
                            Hi guys,
                            Two years in the field, they are still holding strong. Much to my delight, two years ago these DIY were worth it, today with prices having dropped Id be hard pressed to make more, but it was fun and will be interesting to see how they pan out. Ill post yearly updates for those interested hopefully some photos as we go.
                            The panels power my old mans cabbin, which he has retired to. They run a 24" LCD TV, Digital Tuner, Laptop, Surround speakers and 5 or so 15w lights off the panels, on average they are using about 60ah a day for all their needs, 400ah of T105 has held up for the last few years, still holding strong. Amazing to think two people can live off 60ah a day, but they've done it for two years, they said the LVD cut in once after two weeks of rain. They lower their usage accordingly but pretty cool to see. They are planning to up the TV size to 32" LED and drop the surround speakers, which should equal out to the old fluro driven LCD and old speakers.
                            Once the Trojans slow down , hopefully they get another 2 years out of them, Ill probably have a go at setting up a lithium 200ah battery bank, with the trojans as backup perhaps.
                            • jestronix
                              • Nov 2009
                              • 41
                              #44
                              so 6 or 7 years later, one panel died, the rest are putting out normal amps! amazing they survived, some have slight moister in the cells, but this was from day one when they were sealed. So how long will they last now days panels are so cheap i would never bother doing this again, was fun at the time. I picked up a heap of 190w used panels for $50 a pop, they have no leaks and put out full amps, but i guess now you can make huge panels for the same cost i did back then. will find some pics and short amp readings when i get round to it.
                                Thanks for the update!
