WE Energies to Squash Distributed Renewables with their latest rate case.
Actually it can and has be done with three separate transformers. Anyway maybe a picture well answer your question.
Left side a WYE transformer like 208/120 where you can take power from Phase-to-Phase which is 2098 volts, and on the right is Delta. Take note either can be made with separate transformers, just a matter of wiring it together. A good example to use 3 transformers is when you cannot fine a 3-phase of high enough power, or will not physically fit in the designated space. They are real easy to spot if you know what you are looking for on distribution lines. Up on a pole you will see 3 transformer side by side.
MSEE, PEComment
Hunt with a Barret? Well maybe Elephants and Grizzly Bears. But its primary purpose is for hunting men or women, not animals. I can just see Bambi getting shot in the shoulder with one. Not going to be much eatable meat left.
MSEE, PEComment
People use them for silhouette shooting. 1,000 and 2,000 meter competition. One of our neighbors who is big into silhouette shooting has a custom one with a 44" Freshour barrel and too many other modifications to even remember what he told me about it. The optical sight alone on it cost over $10,000. He can shave the hair off the balls on a flea with it at 1,000 meters. The balls on a squirrel ain't safe at 2,000.off-grid in Northern Wisconsin for 14 yearsComment
Dereck,Actually it can and has be done with three separate transformers. Anyway maybe a picture well answer your question.
What you have illustrated is how you can connect any number of single phase loads to a three phase system.
But if you do the circuit analysis, an unbalanced single phase load (say from S to N on the left) will be converted into an unbalanced load which appears only between two line on the right.
The transformer, handy as it might be, cannot convert a single unbalanced load on the left into equal (balanced) line currents on the right side.
The original assertion was that you could not possibly wire a single single phase load on a service in such a way that POCO sees a balanced load (equal line currents). Instead POCO must take a statistically useful number of single phase customers and distribute them evenly across the three line-to-line phases (if delta) or the three line to neutral phases (if wye) to balance the load on their generating facilities.
To do that power distribution over the three phases requires either an active power converter with DC in between or a rotary converter (motor generator) where the driving force is taken equally from all three phases regardless of the balance on the output, load, side.
This question is totally separate from the question of cancelling out triplen harmonics by converting them to circulating current in a delta, which is not seen by the generating equipment.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
That is correct. You cannot run a balanced three-phase generator or source with unbalanced single-phase loads on it. Never in my experience have I seen it.The original assertion was that you could not possibly wire a single single phase load on a service in such a way that POCO sees a balanced load (equal line currents).
To do that power distribution over the three phases requires either an active power converter with DC in between or a rotary converter (motor generator) where the driving force is taken equally from all three phases regardless of the balance on the output, load, side..
The more common use for rotary phase converters is to convert single phase service to three-phase. They are quite common in rural areas for irrigation pumps where three-phase overhead service is not available. A three phase motor can be wired to provide three-phase service from single phase, without using a separate motor and generator. Although the motor requires an external inertial starter to get it running.off-grid in Northern Wisconsin for 14 yearsComment
We have a 50HP American Rotary Phase converter system here in our lab to convert 240v single phase to 240v 3 phase. It does a pretty good job running our large AC unit and provides 3 phase power for all our transformer tests.That is correct. You cannot run a balanced three-phase generator or source with unbalanced single-phase loads on it. Never in my experience have I seen it.
The more common use for rotary phase converters is to convert single phase service to three-phase. They are quite common in rural areas for irrigation pumps where three-phase overhead service is not available. A three phase motor can be wired to provide three-phase service from single phase, without using a separate motor and generator. Although the motor requires an external inertial starter to get it running.Comment
Yep, I have a small 5 hp rotary phase converter made from a Baldor three-phase motor to run my three-phase lathe and vertical mill from our 240V split-phase inverter.off-grid in Northern Wisconsin for 14 yearsComment
50 HP is a huge single phase load. I built this 7.5 hp for my neighbor a while back; now
I need to find an old 5 hp 3 phase motor to make one for my Bridgeport. Bruce RoeAttached FilesComment
Not sure I'm understanding completely... You are slaving a three phase motor to a single phase motor to use it as a three phase generator? Damn... I've got some potential workshop improvements to make if that's the case. What's the efficiency?4KW system featuring Suniva OPT265/Enphase M215Comment
No, nothing that efficient. No single phase motor. Here a pair of 240V leads are fed to 2
phases of a 3 phase unloaded motor. Some oil capacitors feed power to the motor 3rd
input. Extra caps are switched in temporarily to get it started. The motor flywheels the
power to the third phase. Then the 3 motor terminals are available to run a regular loaded
3 phase motor, perhaps at somewhat reduced power.
Some phase converters have built without the extra motor, but the load motor power
is much reduced. Lots of info available on the internet. Bruce RoeComment
The equipment is where I work. We use that system to test a number of harmonic mitigating transformers and harmonic filters. We also measure the power quality affects of non linear loads using a number of Fluke and Dranetz meters.
I can see the benefits of having a 3 phase power source at your home workshop. You can run some nice big "tools" with it.Comment
Not sure of the efficiency. But you take a regular three-phase 208/240/480V motor and wire it parallel wye for 208/240V. There are three pairs of leads that normally go to the three-phase power source, call them T1, T2 and T3. You wire 240V split-phase to T1 and T2. You wire run capacitors between the T1-T3 and T2-T3 leads. You get three-phase power from the T1, T2 and T3 leads for your three-phase loads.
The phase converter motor won't start by itself. As Bruce said you can use a start capacitor. Or on mine I have a little 1/4hp 120V motor that I use to start it with and spin it up. The phase separation isn't quite perfect because the split-phase source is 180 degrees out of phase instead of 120. So the idler motor makes a little noise until you start your three-phase load, then it smooths out because the load motor also acts as a rotary phase converter and helps even out the amps and phase separation on the legs.
I built mine from a 5hp Baldor motor and it runs my lathe and vertical mill just fine using either our 240V inverter, generator, or the inverter in generator support mode where both the inverter and generator are supplying power to it. It won't, however, run my three-phase Miller Pro MIG welder without starting either the motor in the lathe or the mill to clean up the power a bit.off-grid in Northern Wisconsin for 14 yearsComment
