WE Energies to Squash Distributed Renewables with their latest rate case.
I saw that. I also saw a lot of mumbo-jumbo about their controller:
The JuiceBox controller is the brains of the system. It constantly monitors the state of the battery, the PV output and building load from the inverter and determines the mode of operation based on customer bill rates or other priorities. There is a balance between rates of charge and discharge, operating temperature, depth of discharge and number of cycles that must be achieved to ensure long life.
Does that jargon = double the life I wonder?4KW system featuring Suniva OPT265/Enphase M215Comment
I suspect it would only be cost effective where the POCO has very high rates especially at peak times that extend into evening hours and has a combination of minimal payment for over production and a restrictive implementation of net metering (e.g. monthly trueup, non-combinable buckets for peak and off-peak, etc.) Just looking at my own usage and a WAG, it might at best save $2/day for 6 months and maybe $0.50/day for the rest of the year. Let's be generous and say $500/year. If the battery lifetime is ten years, unless it costs quite a bit less than $5K, I'm not sure it would be worth it.I see. It may give you the ability to use less Utility power during peak times. Or if the Utility pays you much less than what they charge you per kWh why not use your battery instead of using the Utility.
Still unless the cost is low I will follow the rule that the $/kWh generated from a battery system is still many times more than from the Utility.Comment
After some additional thought, I think I overestimated the benefits and it would be unlikely to be more than $300 a year.Comment
Exactly what I am trying to say. Sure it can save people with high electrical tariffs but what you save will be a few dollars to what I believe you will have to spend to install that system and maintain it.
Of course I am estimating a high cost for it but when they do not show any $ amount and provide a lot of double talk I feel the price will be a shocker to a home owner.Comment
It would be worth it just to show the utilities that partial defection is possible. I'd sign up just to break even. Some utilities might embrace it since it could help to shave peak demand.I suspect it would only be cost effective where the POCO has very high rates especially at peak times that extend into evening hours and has a combination of minimal payment for over production and a restrictive implementation of net metering (e.g. monthly trueup, non-combinable buckets for peak and off-peak, etc.) Just looking at my own usage and a WAG, it might at best save $2/day for 6 months and maybe $0.50/day for the rest of the year. Let's be generous and say $500/year. If the battery lifetime is ten years, unless it costs quite a bit less than $5K, I'm not sure it would be worth it.
Somehow, with work like this, it appears we are inching ever so slowly to the solar promised land.Comment
Exactly. I have two branch circuits in mind already... Also, purely as a mental exercise (since winter is approaching), I'm going to calculate the size/height ratio of a reservoir system that can store my 13kWh maximum daily excess (yes... a personal PHS system). I'm expecting that it'll probably be hilarious...4KW system featuring Suniva OPT265/Enphase M215Comment
Right now most solar PV systems already help shave peak demand for the Utility. And they don't like that because they lose money. It all comes down to how a Utility determines what is profitable and what is not.It would be worth it just to show the utilities that partial defection is possible. I'd sign up just to break even. Some utilities might embrace it since it could help to shave peak demand.
Here in Florida building new generating plants is more profitable to the Utility than purchasing some of the existing private smaller plants that can't compete with the big guys. Going solar is also an uphill battle for the homeowner even with a grid tie system.
If you look at Hawaii where the going rate is about $0.55/kWh there has been a proliferation of people installing PV systems. Now the Utility has pretty much stopped new connections from happening because they say that their grid can't handle all those local generating systems which can cause voltage imbalances (which is only partly true). So some have gone off grid only to find out it is costing them about $1.0/kWh to generate their own power. No savings there and no pressure on the Utility because they really aren't losing that much income from the off gridders.
I wish you were right that the Utilities would embrace more people installing solar. But some Utilities don't want to give up the monopoly of power generation so will fight to get back what they lost because they were forced to meet a State goal of a % of all generation that has to come from Renewable.Comment
kwilcox, I have another idea for you to use up that daily excess. Have you heard of Electric Thermal Storage?Exactly. I have two branch circuits in mind already... Also, purely as a mental exercise (since winter is approaching), I'm going to calculate the size/height ratio of a reservoir system that can store my 13kWh maximum daily excess (yes... a personal PHS system). I'm expecting that it'll probably be hilarious...
Take a look at this product.....
Here is how I am using the product. I set up the off peak and on peak timers to only charge the unit between 10am and 2pm (ie when the sun shines), then I release the stored energy into the house at night or early morning. Yes there are transfer losses but it is still better than selling my excess energy to POCO at $.035 kWh.Comment
Rather than pay a high price for this type of thing just build your own or have one built. This is just a pile of dense bricks in a box with a heater coil.kwilcox, I have another idea for you to use up that daily excess. Have you heard of Electric Thermal Storage?
Here is how I am using the product. I set up the off peak and on peak timers to only charge the unit between 10am and 2pm (ie when the sun shines), then I release the stored energy into the house at night or early morning. Yes there are transfer losses but it is still better than selling my excess energy to POCO at $.035 kWh.[SIGPIC][/SIGPIC]Comment
+1 on the DIY thermal storage. More flexible for shape, size, placement and almost certainly cost. Still. heating anything with resistance electricity is like cutting butter with a chain saw.Comment
I'm handy, but not that handy.....and besides I think I would have a hard time getting it UL approved just in case I want to keep my homeowners insurance.Comment
You might try buying a UL listed heater coil - easy. You wouldn't have to be handy for this one - you just don't realize or want to admit how simple it is.[SIGPIC][/SIGPIC]Comment
I just got a letter from WE Energies offering me a 10 year grandfather period on my rate plan because they "appreciate that you made the decision to install your system based on the rates that we offered at the time" and "we fully appreciate the financial impact of your investment in solar generation technology". I also got the phone number for their Senior VP - Customer Services with a request to call back with any questions. I'm going to counter with a 20 year transferable...
They must have noticed my efforts on their facebook page to add clarity/counterpoint to their anti-PV campaign....
Check it out at dubdubdub.facebook.com/WeEnergies (I don't think I should be linking there so just replace "dub" with "w")Last edited by inetdog; 10-02-2014, 02:04 PM.4KW system featuring Suniva OPT265/Enphase M215Comment
So the squeaky wheel gets some grease.I just got a letter from WE Energies offering me a 10 year grandfather period on my rate plan because they "appreciate that you made the decision to install your system based on the rates that we offered at the time" and "we fully appreciate the financial impact of your investment in solar generation technology". I also got the phone number for their Senior VP - Customer Services with a request to call back with any questions. I'm going to counter with a 20 year transferable...
Looks like some of your activity got their attention and maybe a good resolution for you.Comment
