Offgrid inverter
  • Agpilot
    • Sep 2021
    Offgrid inverter
    Hello,
    My main question is what is the best offgrid inverter to buy? I currently have a 12kw, 48V growatt inverter-charger with built in controller. Built in China. I've had it in operation since this past January and already have had to change the board in it once, and now it's repeating the problem I had before the board change. My system consists of 2 arrays, 7 strings each, 3 panels each string, 315 watt panels. Combiner box below each array. 1- 7000 watt mppt growatt controller for 1st array and 1- 12kw growatt inverter/ charger with built in controller for 2nd array. I have 6 Lithium iron phosphate 48v, 100Ahr batteries. System works great for our complete home but the inverter started shutting down about every 2 weeks or so and progressively gets worse over time until it shuts down 3-5 times a day, unacceptable.
    I'm looking for a GOOD inverter that'll last for the long haul, preferably American made. Do any of the gurus here have any suggestions?
    Thanks for any input.
    If you want to wait some amount of time, Midnight Solar will have their B-17 "soon" . It's at several beta sites for testing, quite robust
    Otherwise, a solid one I can recommend is any of the Schneider XW series of inverters, pure sine, integral transfer switch for generator and grid
    One solution for grid-interactive & off-grid, residential & commercial, solar & backup power: the XW+ NA solar hybrid inverter system. Learn more.
    • Agpilot
      • Sep 2021
      I do like what I read on the B-17, hopefully this growatt inverter will last until the B-17 is out. I'll be anxiously watching.
