Solar backup system vs generator
I agree with Mike. In four hours my freezer doesn't lose more than a degree or two. I can use my phone as a hot spot and I have enough power tool batteries to have enough light to fix a meal and keep my phone charged.
That being said, our public safety power outages here can last for days, so I have a 10 kWhr battery bank that runs a hybrid inverter. I also have a 5.7 kW grid tie system that can be AC coupled so that it could power the home and charge my EVs enough to get them to a nearby public charging station. I don't know the reliability of the grid in Indonesia, but as mentioned in the earlier comment, the backup strategy should reflect the probabilities.
I don't know how to translate VA into kWhrs. For example, I have a 200 Amp electrical service at 240 volts but 10 kWhrs of battery capacity is enough to get me through the night with some margin of safety until my solar starts producing. I don't normally use anywhere close to the capacity of my panel..Last edited by Ampster; 02-13-2020, 01:19 AM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
do you also have a generator standby?Comment
Yes, that is correct. So far our blackouts have most often happened during periods of clear weather. Despite all the advice on this forum I have not felt I needed to spend the money on a generator. I do have several back up strategies in the event it is cloudy and my solar panels are not able to charge my batteries. My strategy is unique to my circumstances and I am not suggesting it is the best strategy for everyone.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Ok, thats great.
Do you think you need your genny if "blackout" occurs during sun peakhours till the next morning or do you in that case reduce your energy consumption to stay within your design limits (DoD) ?Comment
I can easily reduce my energy consumption. If a blackout occurs during sun peak hours, I have enough solar capacity.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Ampster lives in CA and they have a different set of rules for power purchase from the POCO along with blackouts due to fire hazard.
IMO he has made a good decision to use his EV and the emergency power system. But again everyone has a different reason and financial justification to find the best way to produce power when the grid goes down.Comment
Imagine one have an EV and is able to charge it free of charge at his work and the distance to his work is not so far. ..........Comment
