Help with SolarEdge SE7600A inverter
  • jmbergmann
    • Aug 2018
    • 19
    Thanks for everyone's advice... I did purchase the new HD Wave 7600 watt inverter from SolarEdge and installed it today. All is well...
    Just a quick note about the HD Wave vs the prior inverter... While it is smaller and lighter, it definitely doesn't have the same level of construction that the old ones had. I am sure the plastic exterior will hold up since it's mounted in a mostly shaded area, but it doesn't compare to the previous model with a complete aluminum exterior that won't show its age as plastic always does.
    Seems to run a little bit hotter than the previous version does too. I have 25 panels on each of my inverters, and the HD Wave runs about 15 degrees warmer... Again, i'm sure this is fine, but if the HD Wave is more efficient, i'd think it might run a little cooler, assuming that some of the increased efficiency comes from less of the energy turning into heat.
    But anyway, back in business, so life is good.
