Hello,
I have 2x SolarEdge SE7600A inverters, each with 25 panels attached to them. The system has been up and running without issue for almost 3 years. Recently, one of the inverters stopped generating power. Scrolling through the screens on the inverter and comparing it to my other (working) inverter, all of the screens are identical.
I opened up the DC Disconnect portion of the inverter (lower box) of the non-working unit, and water poured out of it. I believe the installer (now out of business), must have left a cover off of one of the conduit junction boxes on my roof and rain eventually flooded the box shorting out the DC Disconnect.
I tested the DC Disconnect and the wiring and it all tests out ok. I even moved it to my working inverter and that inverter works. All 25x panels are giving out 1 VDC as they should, so I can only believe the issue is with the electronics in the inverter itself.
I opened up the upper portion of the inverter to smell for anything burnt, and to look for any components that may have fried and I can find nothing abnormal at all.
I am wondering if there is some small fuse somewhere in the electronics portion of the inverter that I am not seeing, or if anyone has any suggestions as to what I can look at next, short of having to buy an entire new inverter.
Attached are some pictures for your consideration.
Thanks in advance for any help you can offer.
