Are SCE Peak Time Rebate (PTR)/Save Power Days Credits "Real Money" under NEM?
  • jasonvr
    I contacted SCE's NEM department today and got an answer I was not expecting. Because I was a net producer for the year, I'm not entitled to received my Save Power Days compensation. They consider it double dipping. Instead I only get my Net Surplus compensation which is 1/3 of what I should have gotten out of Save Power Days. Guess I'll be unenrolling from that program. Absolutely amazing that they are actively encouraging me to use MORE electricity in order to pay less
    1) If I consume more electricity in a month I can drive up my delivery charges which count against my monthly minimum but will get netted out with generation credits at the end of the year
    2) If I consume more electricity I wold have been a net consumer (even if I had a negative total energy charge) and would have received my Save Power Days money
    3) If I continue to be a slight net producer for the year, I don't get my Save Power Days money, so I might as well not be a part of the program and blast the AC to stay comfortable when the grid is under the most stress
    Totally ridiculous, and of course I can find no place where that is disclosed
  • jasonvr
    Save power days is an add on to another rate (TOU-D-A for me), so no need to switch rates. If they're really not going to give me the credit, I can just unenroll from the program because I'm not getting any benefit from it
    If/when I get an EV, I'll probably get a submeter installed to keep it on the EV rate while the rest of the house stays on the regular TOU, but given the credit I built up due to TOU, it might not even be necessary.
  • TAZ427
    Yeah, next car will likely be an EV for me as well, but my current one is only 6yrs old and treating me well... I'm overproducing by a whopping 20% from PVWatts numbers for my first month. I'm a bit shocked, I thought I must have miscalculated, but PVWatts was giving me the same annual numbers as 4 different installers suggest an 8kW system at my location would give. I triple checked all other numbers (angles, azimuth, roof mounted, ...) I might have gotten a couple percent because of slightly lower than average temps for June, but nothing to indicate 20%, so I'm talking me wife into allowing me to drop the temps down a couple degrees on days where the Whole House Fan can't be used over night to keep the heat build up in the walls down a bit, and check the consumption numbers after that.
    Would you be going the EV TOU rate when you get an EV? If so, and there's a similar rate plan as the TOU-D-A but no credit for Power Days, I'd switch to it since you're effectively not getting the credit, but you're paying the 'penalty' with the Power Days.
  • jasonvr
    Definitely still enrolled (and even if I wasn't they'd still owe me the credits from last year). On my bill it says:
    You are currently enrolled in the Smart Energy Program, formerly called Save Power Day Incentive Plus. When an energy event is
    activated, your smart thermostat service provider may remotely adjust the temperature on your thermostat to limit A/C usage in
    exchange for bill credits. Thank you for your participation.
    Rate is TOU-D-A
    I knew about the NEM credit and getting compensated is a horrible rate of return. I hope to get an EV in the next few years which should fix that. In the mean time, maybe just more AC
    I think I'm going to have to contact SCE to see what happened to my PTR credits
  • TAZ427
    Ok, I missunderstood, that was you're annual True-Up. I was thinking it was your first month bill. Are you sure you're still on the Saving Power Days plan? I can't even do that on SG&E w/ new Solar Install.
    You're definitely screwed on the NEM credit, it goes back to a 0 balance, you get that $10.90 value of it about $0.03/kWh.
    Your bill should say something like 'Rate Schedule: ETOUB B Residential Time-of-Use Service', Enrolled Programs: "Net Energy Metering (NEM2)"
    I believe the billing looks fairly similar across the CA PoCo's due to state regulations (at least the example bills between different CA PoCo's I've seen have been that way.)
  • jasonvr
    Hmmm, my climate credit and PTR credits NEVER got applied to my minimum monthly (~10/month). They always got rolled into my running "energy charges" which just got trued up. The only times my bill was below $10 was when I was under-producing in the winter and had positive net delivery charges. My relevant period should have ended 6/13 (exactly 1 year after going onto NEM), but it is unclear if they just extended it until the end of my June bill or not.
    Net surplus compensation was because I did overproduce for the year by 354kWh (my first year and I was still being somewhat conservative on my usage to make sure everything worked out). 354 x 0.03080 = 10.90.
    Note that as of January 1, the Save Power Days program seems to have drastically changed. In the old program they looked at previous average usage and for every kWh you save compared to that, they gave you $1.25. In the new program there is a flat $10/month incentive to be in the program, plus something like 7 cents/kWh you save. All of my credit were for 2017 under the old program.
  • TAZ427
    You should get your $40 (or whatever it is) power days credit and it should be applied directly to your bill, just like the Climate Credits are. They'll be eaten up by the end of the NEM year with the $10/mo minimum delivery chargers.
    The TOU credit will get get sucked back down in months where you're under-producing (assuming system is designed to only produce your annual average production) not sure how you got a $10.90 Net Surplus Compensation on this bill (assuming I'm understanding this as the ~$0.03/kWh that if you have any extra production at the end of the NEM that they'll give you.)
    I wonder if this if they do something special where they run the NEM from July 1 - June 30 or something, and you got one month at the end of the year, and thus got both credits, plus the EOY close out.
    Next months bill should be interesting for you.
  • Are SCE Peak Time Rebate (PTR)/Save Power Days Credits "Real Money" under NEM?
    I just got my first true up bill under NEM 1.0 and I feel like some money has gone missing.
    I did over produce for the year by 354 kWh providing a whopping $10.90 in Net Surplus Compensation (I guess I'll just have to use more electricity this year)
    I had a gigantic credit for the year (almost $900 due to TOU rates) - this doesn't actually mean anything, I know
    I got my two CA Climate Credits for $31 and $36
    I participated in Save Power Plus days and according to my bills had a total of $33.75 in credit
    On my true up, the calculations came out like this:
    +31 - CA Climate Credit
    +36 - CA Climate Credit
    +10.90 - Net Surplus Compensation
    -9.80 - New months minimum charge
    Creating a $68.10 net credit. The 10.90 got rolled forward (per my preference for Net Surplus Compensation) and they list a $57.20 refund coming my way. Where did the Save Power Days/PTR credits go? I was under the impression those were "real money" just like the CA Climate Credit and either should get rolled forward or refunded. Am I totally wrong which basically makes being in that program totally worthless to those on NEM who run a negative balance for the year (even if not over-producing)?
