Battery Charging Parameters
  • GreggN
    I'm trying to set up my new charge controller and need some advice on charging parameters. I have a bank composed of 4 Vetus 12 volt sealed batteries on my boat. The batteries are about 5 years old. I don't have the instructions that came with the batteries and Vetus has been of no help. The stick on the batteries says:
    Boost voltage 14.5 - 14.9 volts
    Float Voltage 13.6 - 13.8 volts
    Is the Boost voltage the value I should set for absorption? or is this an equalization voltage? My bank is wired for 24 volts so I will be multiplying by 2
    Any advice appreciated
  • BackwoodsEE
    • 217
    For comparison, here are the 12V battery voltages for the Morningstar TS-MPPT-150.
    This table has me a bit confused because I thought sealed batteries shouldn't get equalized.
    • littleharbor
      • Jan 2016
      • 1998
      Some Mfg. recommend a "boost charge" for AGM batteries. It is an elevated voltage level but generally not enough to cause over gassing as you would see in flooded batteries. Sealed batteries, AKA VRLA(Valve Regulated Lead Acid) recombine the hydrogen gas back into the electrolyte but can only recombine so much before pressure causes the valve to open and vent. This venting causes loss of electrolyte which these batteries cant afford to lose. AGM batteries are roughly 98% saturated glass matt. loss of electrolyte is detrimental to them as it cannot be replaced.
        Ho do you use your boat? Every other weekend would be the FLOAT settings. Daily usage I think would be for the Boost. Since they don't define the terms, I can't be sure.
        I'm thinking some batteries have different charge profiles for Daily Cyclic Use (Boost) or Standby Use (Float)
        AGM does not want much extra charge after the battery is filled.
          Vetus uses "boost" as equivalent to "absorb".
          • NEOH
            • Nov 2010
            • 478
            What is the Make & Model of this new charge controller?
            Why did you change Charge Controllers?
            ALL manufacturers recommend a Boost / Bulk Charge Mode for their Deep Cycle AGM Batteries.
            YES => The Boost Voltage on the sticker is the Absorb Voltage in the Charge Controller, start at 29 Volts = 2 x 14.5 Volts.
            Your batteries are 5 years old, the Final Charge Voltage and Amps to get to 100% SOC will be different vs new batteries.
            How many more years do you think they have on this bank of batteries?
            Some AGM battery manufacturers recommend a Special AGM Equalization ( Recondition ) Charge mode, some do not.
            Vetus 24 Volt 40 Amp Charge Controler ...
            https://www.vetus.com/electricity-on...-24v-9952.html
            The above charge controller, simply does an 85 minute Bulk Charge every 12 days, which is NOT a true Equalization Mode charge.
            Exactly how does the "Equalization Mode" function on this new Charge Controller?
            I would not activate the Equalization mode on the new Charge Controller until I knew exactly what it was doing.
              Do not get tripped up with catchy names like Boost, Equalize, Float or Bulk. For the most part it is garbage marketing of so called Smart Chargers. . They all mean the exact same thing and all are CC/CV. The names are just voltage set points. Nothing more, nothing less.
              The stickers give you the min/max values.
              Depending on your controller you want to set Bulk/Absorb from 29.0 to 29.8 volts, and Float to 27.2 to 27.6 volts. Being they are 5 year old AGM's are already due for replacement, and on solar go for the max voltages. 14.9 and 13.8 volts. There is no chance for thermal runaway on solar.
              • AncelB
                • Jul 2017
                • 18
                Hi all:
                My first post. Pleased to join the community.
                I taught basic Photovoltaic system design at a Tech. Voc Institution and I am an Engineer with MIT EE certification.
                Anyway, lead acid batteries are a particular expertise of mine.
                All lead acid batteries benefit from equalization or limited overcharging to eliminate electrolyte stratification and sulfation of the cells due to individual cell imbalance in the charge voltages in a long cell string.
                The caveat here is genuine GEL batteries cannot be equalized or they will form irremovable bubble voids in the gel and degrade battery performance. GEL batteries don't stratify the electrolyte at all.
                In the case of VRLA batteries such as AGM or even flooded cell recombinant batteries, equalization is beneficial, but overdoing it can compromise the electrolyte volume due to H2 and O2 losses. Increased electrolyte concentration will accelerate battery corrosion but provide higher cranking amps in the short term.
                The key to improving Lead acid battery longevity is to ensure their temperatures are cool (20C) .
                  Originally posted by AncelB
                  Hi all:
                  The key to improving Lead acid battery longevity is to ensure their temperatures are cool (20C) . For every 8.3
                  You are preaching to the choir. The OP has Vetus AGM, not Gel. Voltage settings tell you it is not Gel as indicated by the voltage settings on the batteries. Welcome to the forum.
                  Gel batteries use lower voltage and slower charging algorithm to help prevent drying and cracking. They are not suitable for solar applications. Gels are pretty much limited to Float service in Emergency Egress Lightning and Fire Alarm Systems charged at a slow C/20. Solar needs much higher charge rates up to C/2 in some parts of the country.
                  • AncelB
                    • Jul 2017
                    • 18
                    Pls have a look at this DIY effort of mine:
                    A spin-off circuit from a 5 yr project with proper science, instrumentation and a lot of effort. https://www.youtube.com/watch?v=Dd0HBqpBgok This multiple award winning project is being commercialized @ protofabtt@gmail.com. I wanted to enable the DIY community worldwide to be able to perform both 'manually monitored' and DIY-automated lead acid battery regeneration from the perspective of cost effective recycling by mitigating spent battery transportation & remanufacturing and the carbon footprint associated with it. The approach is suitable for all types of lead acid batteries . Now HEV (NiMH capable and soon Li-Ion ready) No chemicals are required.Note the B4 and after (overnight) pics of a regenerated cell in an car battery and the removal of the white sulfate. Process is also Deep Cycle ready.This project = 2 phases. 1) Just the pulse/charge engine with integrated snubber and optoisolation for up to 250W of RMS pulsing @ up to 800 Amperes pulsed.2) A PWM pulsing c
                    • max2k
                      • 819
                      https://hackaday.io/project/25741-de...nge-mitigation
                      I wonder if the overall idea works at all: many moons ago I tried to commercialize car batteries desulfation and the conclusion was this problem doesn't really exist if the batteries were maintained properly. In scope of that project we opened old batteries to analyze what leads to increased Ro and we found out the most common reason is breaking off battery 'subelement' electrodes from their element's 'output' bus. This caused switching out of entire subelement losing its useful area and hence increasing Ro. This effect seemed to be related to the current density and caused corrosion right at the spot where subelement was connected to the common 'bus' so one ends up with battery where elements look OK but they are not connected to anything.
                      One battery design surprised us a lot- they made element grid not out of perpendicular line conductors but rather from radially spreading conductors all originating from the output point of the subelement. These batteries were losing outer areas of subelements when aging but never broke off at the spots where subelements were connected to the element 'bus' as cross section of the lead was increasing towards that point. They had Ro in vicinity of 12-15 mOhm at 7 years of age. Their problem was electrical leaks developed by accumulating sediments at the bottom of the cells but they were quite capable of starting car if they were just charged.
                      • AncelB
                        • Jul 2017
                        • 18
                        The regeneration applies mainly to batteries which were not maintained properly and thus sulfated. Statistically this is between 20 and 33% of defunct batteries. At least from the few hundred I have done.
                          For the most part battery desulphators are more voodoo, than science. 95% of all battery failures are sulphation. The two root causes are the natural aging of batteries, and/or chronic undercharging. Even well maintained batteries will die from sulphation. You cannot stop it, only minimize it.
                          The other 5% is what you mostly see in auto SLI batteries, corrosion just as you describe. A SLI battery is not a deep cycle battery. As you noted a SLI battery plates fill the jar to the bottom. Where as a True Deep Cycle battery doe snot completely fill the jar. They leave room in the bottom of the jar for sediment, flaking, and scaling. Helps prevent the plates from shorting out.
                          Although this discussion has anything to do with the OP because he is using FLA batteries. Solar has revised battery manufacturers charging guidelines. Before Off-Grid became popular the users of Deep Cycle Batteries were Golf Carts, Fork Lift, Floor machines, and some Marine and RV users. All those users just became accustomed to replacing the batteries every 2 or 3 years. Charging guideline were written for Ac chargers that do not have power or time limits.
                          A great example today is Trojan. Before Solar Bulk/Absorp was 2.35 to 2.4 vpc (14.1 to 14.4 volts). Not today. When solar users used those voltage guidelines, battery manufactures got slammed with warranty claims. Solar charging just falls short as there are not enough hours to apply a proper Saturation, aka Absorb. Secondly most solar users panel wattages are grossly undersized. compounding the problem. As a result, battery manufactures discovered the failures were chronic undercharging, or sulphated batteries.
                          So they change charging guidelines and raise charge voltages. Case in point Trojan upped it to 2.45 to 2.5 vpc or 14.83 volts on a 12 volt battery. In a solar system you want to error on the Corrosion side of the knife. Over charged batteries last longer than undercharged batteries.
                          • AncelB
                            • Jul 2017
                            • 18
                            Challenge therein is enough sunlight regularly to do the job, else sulphation will set in.
                              I'm trying to set up my new charge controller and need some advice on charging parameters. I have a bank composed of 4 Vetus 12 volt sealed batteries on my boat. The batteries are about 5 years old.....
                              At 5 years, they are likely at end of life, unless they are very unusual batteries. What does the warranty period say - 24 or 36 months ?
