Here is a pic of my junction box showing the diodes.It's a 100 watt panel.My question is: Is the left one a bypass diode and the right one a blocking diode? Could either one cause low power output? diodes.JPG
bypass and blocking diodes
If either has failed then the voltage and current output of that panel would be lower than nameplate rating.
More than likely a failed diode will create an open circuit and isolate a number of the pv cells depending on which one failed. -
Blocking diodes are seldom. if ever, used in a PV panel. Blocking function is nearly always performed in the Charge Controller
Bypass diodes are often found in the J-box of the panel. They should be a Schottky type of diode, lower loss and heat generation than a plain diode.
use conventional means to test them
Last edited by Mike90250; 05-06-2017, 07:14 PM. Reason: Blocking function is nearly always performed in the Charge ControllerPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I think your panel is divided into 2 sections, and each diode parallels a section, to serve as a bypass if that section
were shadowed. The diodes should run completely cold in sunny operation, carrying no current. A meter would
show half the panel output voltage across each. If a blocking diode were in use, it would be in series, not parallel,
and show something like 1V forward drop when current was output.
If a bypass diode were to open, it would have no effect on sunny operation; an open blocking diode would stop all
current. A shorted bypass diode would run hot and eliminate about half your panel output voltage. A shorted
blocking diode wouldn't prevent operation, but would allow back (battery) current at night. Bruce RoeComment
It's very odd that the Voc and Isc are within specs but under load I can only get about 30 watts out of this 100 watt panel.See my previous post : low solar panel output
Voltage under load is about 14V and 2A current The only thing I can think of might be a COLD solder joint on one or more of the tabbing wires or buss wires.Comment
Since you have access, check for equal voltage UNDER LOAD across the 2 diodes. Might be one section is weak.It's very odd that the Voc and Isc are within specs but under load I can only get about 30 watts out of this 100 watt panel.See my previous post : low solar panel output
That might not show up on a simple OC/SC test. Bruce RoeComment
OK It shows 10.6 across each diode, which is about right, but under load I still can't get over 31 watts .I guess I'll just give up on this panel.Anybody want it? May you will have better luck.Comment
