Was just wondering is ther a limit to how many panels you can join up in parellel using mc4 Y branch connectors before using a combiner box
Mc4 connectors
Current limit is determined by the size of the wire used. The more you have in parallel the higher the current.3.6 kw PV, Classic 150, Radian GS4048A, LFP 195A -
Two strings is usually the limit, because above that the individual strings need over current protection anyway. I have found the MidNite combiner boxes to be a good value and it helps keep all the wiring neat and indentfiableComment
Ok thanks heaps I was just trying to make it easy for myself I have a heap of branch connectors but no combiner box the nearest shop is 400km away so all my new toys will have to wait cheersComment
The limit is based on the current rating of the connectors, usually 20-30 A. If you combine more than two panels, you can still avoid a junction box if you put an mc4 inline fuse on each panel.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Yes, the inline fuses can be done but it can soon become a hornet's nest of ugly wiring, and then there's no good disconnect, no good string isolation for troubleshooting or upgrades... not to mention a good space for labeling etc.Comment
No probs was thinking I might make my own combiner box to save some coin ...would putting 2 bus bars +&- putting all cables in and having a 40amp breaker fuse between it and charge controller should work ehComment
Each string needs it's own breaker. By the time you have everything together the MidNite combiner looks like a relative bargain. Plus it already will pass inspection when wired correctlyComment
Ha ha didn't realise that I wonder if all them blokes on YouTube still have houses ... cheers b17 your advice has been invaluableComment
Just watched a YouTube video of a guy from renogy which is supposed to be a good company using branch connectors to connect 4 strings together with no fuses ... now you guys are confusing meComment
No fuses with more than two parallel panels is a bad idea, not compliant with the panel's installation instructions or any applicable code.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
