Water fountain pump
it's very odd that this used to work fine and now I am having these issues. The sun is out today, so I disconnected it and connected battery, panel then load and within 2 min, the pump stopped. I had been running it through CC without the panel connected all day yesterday. Not great output. So after it didn't work today when I disconnected and reconnected, I bypassed the CC and battery and connected the panel to the pump. GREAT output! So this tells me I am losing power with the CC also. My battery is at about 12.2 now. Should I forget all this and trench a power line? I hate to give up! This has to be able to work. I have a big enough set up it should be able to keep up and run my pump 24x7 and keep the water clear. HELP!Comment
12.2 is about 55% SOC meaning your battery is essentially dead. I set my LVD to 12.0 or 50% However most cheap Chinese CC's will not cut out until 11.5 therefore damaging your battery. I think your battery is dead and or damaged from previous over discharge. You need to connect your battery to a stiff AC source, A smart charger powered from AC current, or generator ASAP!
Well that CC should work. You say that if you just hook up the battery and then the pump it works but if you also connect the solar panel it does not?
Right. If I disconnect and then reconnect battery, panel and then pump, the pump runs for a bit and then CC doesn't show any load connected. Maybe there are setting I don't have right or something, but I couldn't find anything. Normal display is when the panel is connected, I see a panel, when battery is connected I see a battery (with flashing arrow between panel and battery telling me it's charging) and when load is connected I see a picture of a light bulb. So when it runs a few minutes, the pic of the light bulb disappears and no output to the pump.
Based on what I read in the add the CC will shut off the load if the battery voltage goes below 12.6volts. It might be above that when you start the pump but the battery discharges too much and the low voltage cut off shuts it down.Comment
Some Solar Controllers (not called Charge Controllers) have a feature which lets you use the Load terminals for solar lighting. When there is power coming from the panel it figures it is not night and it turns the lights (Load Terminals) off. Read the manual to see how to change this option.
And consider attaching the pump to the battery directly, with an external Low Voltage Cutoff (LVC) relay. The Load terminals, when set for LVC, let the battery be drawn down too far, to too low a voltage.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
He would need to install some type of relay that turns off the pump after a period of time or just run the pump 24hours a day. Hopefully the battery will not get drained.Comment
It sounds like he may need a time-of-day controller for the pump instead.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
There is a Work Mode setting that defaults to 24H. I assumed that meant I want it to run for 24H. The discharge stop is at 10.7 and the discharge reconnect is at 12.6. Not following what that means. Discharge stop I understand is probably that the load cuts off, but what is discharge reconnect? Seems like very little play room here between charging and discharging for it to run all night.Comment
I agree some of the controllers use the sunlight to determine when to run the load if it is only a light. But others just have a time duration setting based on a number of hours. I will have to go back and check to see what is the trigger point or if you can program the time of day.Comment
I agree some of the controllers use the sunlight to determine when to run the load if it is only a light. But others just have a time duration setting based on a number of hours. I will have to go back and check to see what is the trigger point or if you can program the time of day.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Yes I am beginning to wonder about he controller. I had nothing connected and the load display was on and shut off. I am running it now with panel not connected. Just battery and pumpComment
