Your power usage before/after solar?
My dear boy don't you know electricity is fungible?
My neighbor, not having a whole house fan as I do, uses is AC all the time. Being the lowest impedance source no doubt I'm feeding his panel. But since my house is cool and I'm TOU, my usage is quite low during peak solar. Meanwhile - here's the key point - less NG was used to produce electricity as my panels made up for it. Late in the day my house is heated up and his is quite cool, so I crank up the power usage and am using NG generated electricity, which was saved (due to the fungibility) during the day.
Let's not argue about NG plant efficiencies, peak power generation and the like, the point being that yes at the end of the year I am removed from the fossil fuel generation equation, even though some of my electrons came from a NG plant. Makes no difference, just as using your credit card is no different than cash.
Now now, be nice.
Even Germany produces over 50% of their power from coal and they have a very large portion of their power coming from RE.
So forgive me if I feel you are deceiving yourself into thinking you are not using or you are "removed" from fossil fuel.Comment
On the first house I owned, I installed solar almost right away after moving in - so I didn't have good data. We didn't have A/C so our bills were low to begin with. A 3.4KW system covered almost all our usage.
Our second house was a more interesting story. When we moved in, it had a very old (but working) 10kW solar system. It was enough to bring the previous owners down into the lower tiers, but they were still using ~60kwhr a day. We installed setback thermostats, switched to CFL and LED lighting, reprogrammed the pool pump etc and brought consumption down to about 18kwhr/day. At that point we were generating almost twice what we used.
So we got an EV. Then we had two kids. And consumption climbed up to about 25 kwhr a day. We are now just about zeroed out in terms of generation. We still generate a bit more than we use.
So we got an EV. Then we had two kids. And consumption climbed up to about 25 kwhr a day. We are now just about zeroed out in terms of generation. We still generate a bit more than we use.Comment
FWIW, I can report similar usage and scenario without the children. Question: Does current annual generation match annual usage ? A 10 kW system, even a bit long in the tooth ought to be good for > (25)*(365) = 9,125 kWh/yr., in most places. I get that out of a 5 kW system.
Once we are back to normal I expect to see a surplus again.
We are just about matching production for this year. Part of the reason for this is that my house is a test bed for an adaptive power control system that my company is working on, and while it now works pretty well, during the startup phase they were sometimes using 80kwhr a day. (They'd do things like set the pool pump on maximum speed and then the system would crash, and the software guy would forget to tell me, so it would run that way for 30 hours.)
Once we are back to normal I expect to see a surplus again.Comment
Which is why I'm just talking about my carbon footprint being zero (electricity wise), not state wide. However, that's just a technology problem. Given enough storage (which doesn't exist), or a geographically diverse enough grid (which is in progress) that problem goes away, but that's a different topic.Comment
You still don't understand fungibility ... rather than explain it to you, which can be had from some study and thought, I'll point out the possible flaw in this, which relates to the fallacy of composition. Yes, the fact is that I am carbon free, no matter that sometimes the power comes from NG plants. Just like with a bank you don't get back the exact physical dollar bills that you gave it, with electricity it doesn't matter where it comes from, just the net usage. However (here comes the fallacy and possibly the flaw in your thinking), what is true for me isn't true for the state of California. If everybody did what I do it wouldn't work, and would play out as you indicate. Even with 100% solar clearly the state has to use NG at off solar times since it can't store anything.
Is it from some other RE source that is running 24/7 or is it a contract from a supplier that says it is 100% RE?Comment
To put it another way, I only get paid every two weeks; imagine only getting your electricity delivered once every two weeks. That would not work well for you. You are willing to pay for power that can be delivered continuously and in whatever quantity (to the limits of your service) that you require. And that, in turn, requires that someone else build power plants to supply you when your solar system is unable to. Those power plants (in California at least) generate carbon dioxide. Thus your use of power at night incurs carbon emissions in _reality_, no matter what you do during the day.
Our consumption of energy is slightly up.
We converted to LEDs and energy-star appliances before. We were also using oil lamps a lot [due to power outages].
We have two ceiling fans and a circulator pump [that moves water from woodstove to thermal bank to radiant floor]. These are pretty much continuous loads. Except for during power outages obviously.
But now that we are on solar power. My wife bought a dishwasher. She is convinced that a dishwasher uses less water. So now every morning the sun is out, the dishwasher is running.
The biggest feature to account for why we use more electricity now is that we no longer have power outages. When the grid is down and you rely on the grid, obviously you do not use much power during that period of time each month.
4400w, Midnite Classic 150 charge-controller.Comment
Finding ways to conserve electricity, water or any other type of resource is a smart action. Sometimes conserving one type will increase the use of another. It is a give and take process to find a balance of what you need to be comfortable and what you can keep from being wasted.
It is a shame that you have to give up a secure power system due to the grid issues but I guess living where you are has a lot of pluses and beauty.
So what is so different for you that your carbon footprint is zero? (which I really don't care about but that is another topic) Where do you get your power from at night or during rainy days?
Anyhow yes it so happens that my city switched to a 60% renewable supplier and so when I'm pulling from the grid it's 'coming' from them. But then again, it's not, the current sources only care about impedances, really it's an accounting matter involving (wait for it) - the fungibility of electricity. I can switch to their 100% renewable plan which is a little more expensive, but since I'm consuming all my own power I'm not sure what the point is.
The sources are primarily hydro and wind for the 60%, and geothermal for 100%. Oh yes, I live by geothermal plants (within 30 miles), so maybe that'll make you happy for my nighttime usage, but I give up otherwise.Comment
We're probably beating a dead topic as you aren't following fungibility. I think you're thinking the composition of fallacy which isn't applicable, but this has been covered elsewhere.
So I thank you for the information you have provided and apologize for brow beating you concerning your power usage.Comment
