Advice for an incremental build with micro grid-tie inverters
  • Volusiano
    • Oct 2013
    • 697
    Originally posted by getut
    If that is likely to be an issue, is there any way to use grid-tie and ensure it always supplements or possibly supplies up to 100% of a homes need without backfeeding the grid?
    First of all, there will most likely be 2 separate meters, one to monitor your solar production ONLY, and the other one is the main meter monitoring the combination of consumption and production combined. The one for monitoring the solar production ONLY (usually put in place for SREC credit counting by the utility company) will be the one that "gives you away", telling the utility company that your production is above the norm (if you expand).
    Secondly, your question on whether there's a way to ensure that the solar power is used up "without backfeeding the grid" (your own word) is not synonymous with a grid-tied system because the whole idea of a grid-tied system IS to BACKFEED into the grid to get energy credit banked to be used later at a time when there's no solar production.
    I never said I was going to build my own micro-inverters. I WILL build my own panels and expand the existing system by adding a panel and a microinverter every couple of months until my capacity reaches a point I am satisfied with it.
    OK, this clarifies it. But you did write before that you were going to build your own panels and additional microinverters. Unless you meant one thing and wrote another thing due to bad writing. Below is the quote on exactly what you wrote:
    2) Once that is done I want to start with a single panel and single micro-inverter. I will probably buy a high quality pre-made panel to start with, but I want to build the rest of my panels and additional micro-inverters myself as I go and as money frees up.
    • getut
      • Jan 2014
      • 6
      First off you would "always" have to be using more power than your system generates. (That seems like a waste of energy to me).
      But even if you do all it takes is for clouds to come over and the Utility will see wild power usage swings from very little being used when the sun is shining to a lot when it is not. Most homes don't consume power that way and it will probably send up a flag as being strange requiring investigating.
      I believe you are trying to out think the Utility and in the end will probably cost you much more that getting a permit for each addition.
      Just my thoughts but your decision to not comply with the rules is waste of your money and plain dumb.
      I think the rules are set up with traditional large scale grid tie systems in mind. Many of the micro-inverter grid tie system are set up to essentially be hot pluggable. Add a panel and micro-inverter to the end of the chain fasten it all down and make it pretty and done. Getting permits and permission for a plug and play system is just government gone stupid.
      If you look at it in terms of the old large systems and the rules built around those systems then you are right, it is dumb. But if you look at it with a technical eye, the regulations are archaic and protectionist.
      • Volusiano
        • Oct 2013
        • 697
        When it comes to the grid, rules and regulations are there first and foremost for everyone's safety and protection. As far as the utility company is concerned, your system is just a system. It doesn't matter if it's plug and play or not. If you're using the grid, you have a responsibility to follow rules and regulations so that everyone else on the grid is safe and protected. It's not all about you.
        How would the utility company know that once you've modified your system, that's it was done in a safe manner, unless you inform them of the change so that they can inspect and make sure that your modification was done properly and safely? What if some idiot decides to not just build their own panel, but their own inverter, too, and doesn't have a proper shut-down mechanism built into the inverter to shut it off when the grid is down? If not, workers who have to work on power lines when the grid is down may risk being shocked and killed by electricity produced by your panels and still energized by your inverter back into the grid.
        If you don't agree with rules and regulations put in place not just for your own safety but other people's safety, too, then you have no business using the grid. It's not about rules and regulations being archaic. It's about safety and if you agree to use the grid, you have the responsibility to do your part to ensure that you use the grid in a safe and responsible manner for the safety of everyone else around you using that grid, too.
        It's a free country and if you don't like to play by the rules, you can always go off-grid and design and build whatever you want to your heart's content with an off-grid system and nobody else could care less. But as long as you're on the grid, it's not just your own business anymore and it's become everybody else's business what you do to that grid.
          • 15210
          Well stated.
          While I don't like the idea of being told or regulated for everything I do by the Government I will be the first in line to make sure I follow the National Electric code and rules when it comes to the safety of others. The electrical code was not put in place to make it hard for people to do what they want but to keep everyone safe. Based on my work experience I have followed those rules for over 35 years. No one that has ever worked for me has been hurt.
          Go around those safety rules and you open yourself up to hurting or killing someone. That will never be a justification because you didn't like a regulation or thought you could save a few dollars.
          getut
          Just remember that others might not like to follow the "rules" which can and will expose you to the same unsafe practices that you are talking about. Don't you think it would be bad if you or one of your family got electrocuted by that someone? The rules were written to protect you also.
            Your technical eye has something seriously wrong with it!
            SCB's are not welcome in the world and especially on this site. Regulations, codes and standards have been developed to resolve problems seen in the past or potential problems. If you can't understand what the concern is then it is your problem.
            • Wy_White_Wolf
              • Oct 2011
              • 1179
              Let me explain better so some of you will understand, I fully understand about the hooking the system to the grid needing a permit etc. I plan to do the initial install with ALL UL listed equipment and get permits etc for everything that is done but only in the first phase. I also plan to have that initial install all done by my electrician on top of my pole building that I will be building in the spring. But that initial phase will be the most expensive. By the time my electrician modifies my panel and I get all my wiring out to the pole building, I won't have enough money left except to have max 2-3 panels and matching inverters installed in that initial pass.
              But once I have the frame work in place and professionally done, I plan to build my own panels and use them with the same model micro-inverters that I start the project with. I never said I was going to build my own micro-inverters. I WILL build my own panels and expand the existing system by adding a panel and a microinverter every couple of months until my capacity reaches a point I am satisfied with it. That is the "fun" part of the project. Building the panels and expanding my system. This is the part that I simply will not ask the government for permission every time I add a panel or two.
              So I'm trying to get advice from you guys on the specifics. It is important to me to do it right and safely. If it is cheaper to buy them I'd love to know. I don't mind buying the cheap panels from the Chinese market dumping them. Doing this incrementally will allow me to have a larger number of them in the end that I would have otherwise been able to do all at once, so if they start degrading at 10 years instead of 20 or only put out 90% of their rating it doesn't bother me. I'll just add more of them over time.
              Part of that initial hookup will involve a Net metering and Power production agreement with the PoCo. You will have to list the size of your system on that agreement. It will have to match the government permits.
              When you start increasing the size of your system it will be short order before the PoCo realizes you hav increased the size of your system. That will require amending the origanal agreements and reinspection by the PoCo. Once they see the DIY panels and no new permits you will be shut down.
              Sorry but no way around it.
              WWW
              • getut
                • Jan 2014
                • 6
                WWW
                Sorry, but I guess I should have STARTED with my power company. Energy United is a power cooperative and I just got word back from them that adding capactiy would be no issue whatsoever. In their agreement, residential plans are blanket covered for everything up to 20 or 25 kw production. I just got the email a few minutes ago so I'm still not sure which is the limit 20 or 25 because it lists 20 in one place and 25 in another. But I specifically asked about the plan to start very very small and grow the system using purchased expandable micro-inverters and home made panels and he said absolutely no problem. He said the same agreement with them covers generation using any method up to that limit. Solar, hydro, wind, etc. and he said they have some customers using all the above and expanding all the time. BTW.. the company limit was 100kw.
                So kudos to Energy United for having a sane, non-intrusive but logical policy.
                  North Carolina coop power - figures
                    Bet they did not catch DIY panels. Your insurance and electrical inspector will care a lot.. What happens on your side of the meter is of no concern to the POCO. They can careless if you burn your house down out of ignorance, as they do not have liability. Bu tyou can bet the local FD and your insurance carrier care a lot about it and will hold you liable. Not to mention criminal liability for injury and death as a result.
