Raggie
  • AranM0n3y88
    • Oct 2016
    • 76
    Raggie
    I have Raggie 3000 watt pure sine wave inverter
    I have ppl telling me to buy a 1000 watt inverter to use it doing the night time cuz the one I have is too big and the fan is big mean it take more power
    Should I buy a 1000 watt inverter to use in the night time or no they all the same?
    • 15210
    The bigger the inverter wattage the higher the amount of watt-hours burned due to system losses.
    Most inverters have a "no-load" wattage value that is a % of the total watts. That means even if you have no load plugged in you will continue to drain your battery.
    A smaller inverter usually calculates out to a lower % wattage wasted.
    • Logan5
      • Feb 2013
      • 484
      what are running on inverter? Many appliances can be purchased that run native on DC voltage, mostly 12 and 19 volts. You can save big money on heavy expensive batteries by replacing appliances and running an inverterless 24v system.
      • AranM0n3y88
        • Oct 2016
        • 76
        Thank you
        I run almost everything you name it I run it until 3pm that when I turn it off so I can use it doing night time
        Which is better having a 24v system or a 12v system?
        Am thinking of buying two new battery's and putting it on a parallel system. Or having a series System better then parallel
        I want more power that's my goal..to use more
        P.s. Thank you
          What's better, a car or a truck ?
          The larger your loads, the higher voltage systems (24v, 48v) perform better.
          • AranM0n3y88
            • Oct 2016
            • 76
            Lolz ok thank mike
            But I think my solar are 18volt which mean a 12volt system right? Can I use same solar for a 24volt system ? I have ppl telling me the wrong info I guess
            • Logan5
              Logan5 commented
              Editing a comment
              12v is a box many people are stuck in, because they have their "magic box", inverter that they are attached to, Until they learn a 12v inverter system is very limited and for the most part JUNK for off grid living and or quality off grid systems. In general running a 12v system is more expensive than 24v and has much less usable power. With your simi quality MPPT CC you can wire your panels in series and easily upgrade to 24v, you will need a new inverter and a step down converter for your 12 and 19v loads. If you shop around you can obtain appliances that run directly from the battery bank eliminating the need for an inverter all together.
          • AranM0n3y88
            • Oct 2016
            • 76
            Hey mike my mppt info
            Model: tracer 4024
            Voltage: 12/24v
            Current:40A
            Max. Pv voltage :100V
            Max. Pv input power: 520W(12v),1040W(24)
            Now my ? Is it says the max pv voltage is 100V but I only see 15-20Volt on my mppt
            Or it means something else?
              Originally posted by AranM0n3y88
              ...Now my ? Is it says the max pv voltage is 100V but I only see 15-20Volt on my mppt
              Measure the voltage of the PV panels without connecting them to the charger.
              connected to the charger, it will use the power of the panels and lower the voltage you measure.
              if you are measuring 15V at the input of the charger you have a counterfeit charger that is NOT mppt
              What are your solar panels -
              How many
              Wired series or parallel
              Voc:____
              Vmp:____
              • AranM0n3y88
                • Oct 2016
                • 76
                I took my mppt back to them and got my money back ..
                2 riggie and 3 Dubai
                I have 500 watt (100each)
                Right now am using parallel but when I buy a new mppt I would use series wired
                Voc: riggie ( 21.5v ). Dubai ( 22.4v)
                Vmp: riggie (17.5 v). Dubai (18.4 v)
                Can u gave me the best mppt to buy? Right now am lost too many but idk if they gave u want it says n idk if is mppt or not
                Thx
                Am thinking of buying ?
                http://www.ebay.com/itm/EPsolar-eTra...4AAOSw9r1WAQJa
                Or
                http://www.homedepot.com/catalog/pdf...9d8649138d.pdf
                What you think
