Solar to provide 20% of energy by 2027
To assume that technological progress will stop in solar is like saying cell phones will be more expensive and not as good in five years.
Pretty much every person has said "this is going to get cheaper with no end in sight!" (and "this stock is going to keep going up forever!" or "this isn't a bubble - prices will just continue to rise!") has been wrong. Solar-PV is now running into some basic limitations - the price of silicon, the price of aluminum and glass for frames, copper for wiring. You can't make something cheaper than the parts it is constructed from, no matter how little you pay your workers or no matter how much you automate. We will see some small improvements, but the days of order-of-magnitude decreases in cost are over.
And at some point cellphones will hit that limit, and not get any cheaper or better. However, due to the basic physics involved, we are a long way from that. Solar doesn't follow the same scaling factors - you cannot make a solar panel 1/4 the size and increase its power by 4 times. Again, basic physics.
Already, leading thin film solar manufacture is at 16% efficiency and their utility scale installed cost will below $1 a watt by 2017. Thin film has a long way to go. Also Solar City's cost per watt of their solar panels is around 50 cents for a 21.5% efficient module. Higher efficiency modules lower the balance of systems costs. Also,there is a lot of research is being done in perovskite, which is a lot cheaper than silcon solar panels. There is a ton of research going on out there. Obviously, the long-term trend is down.
This gallery has 1 photos.Comment
CrazyLast edited by inetdog; 02-03-2016, 08:26 PM. Reason: Edited for language and tone. Squeep it Cleeky Seen SK. :-)MSEE, PEComment
You wrongly compare the drop in prices in solar panels to a financial bubble. Better technology makes cheaper more efficient panels possible. Technology and manufacturing efficiencies get better with time. Obviously, the theoretical maximum efficiency is 100%, but current solar panels are at around 16 to 20%. There is theoretical minimum to cost though. There is a ton of research going on a solar and a lot of different technologies and type of panels.
already dropped to be a small part of a system cost. Even if solar cells were free, system cost wouldn't drop so much.
Bruce RoeComment
The other issue is the cost to install a solar system. While large Utility scale systems can keep the labor costs down the smaller home system will still keep $/watt up due to wages and over head for the installer.Comment
Comparisons to other countries have also indicated that a significant part of the cost of PV in the US is in permits, regulations and construction delays associated with them. Particularly for large (utility scale) projects.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Not that I want to see wild life disappear or worse go extinct but someone needs to make a decision between clean power or critters.Comment
Thin film is showing a lot of promise, and you never know, that might be awfully cheap to make someday.
The somewhat irrational enthusiasm for rooftop solar sure seems to be driving down the cost of solar...
and at some point, the beancounters are going to say "Damn, solar *is* cheaper", and utilities are going to swoop in and start building huge farms.
HUGE! It's going to be great!Comment
Even Moore's Law, the law that says computing power will continue to double every two years, is running into some fundamental limits. Transistors the size of atoms don't work, and clock speeds faster than the speed of light divided by the distance across the IC don't work either. The research to overcome the speed-of-light issue, for example, isn't going to be as simple as the research to make a smaller MOSFET gate.
Don't get me wrong, I would love to see 10 cent per watt PV. They are simply unlikely.Comment
Yep. And better technology makes cheaper, more efficient cars possible as well. But if we projected trends from the 1940's through the 1960's to today, we would now be driving cars with top speeds over 600mph that got 750 miles per gallon and cost $50. The reason we are not is not that research on cars has been lacking - it's that car manufacture ran into some very fundamental physical and economic limits.
Yep. But they are already a small fraction of system costs. To make big gains from here, we will have to (for example) figure out how to make aluminum, glass and copper more cheaply. And since we have been using them for centuries, we've already made most of the easy/feasible improvements in the process.
Here is a link to projected solar costs through 2030. Analysts disagree with you.
"The chart shows two key trends in past and projected costs of U.S. solar installations. The yellow is the cost of silicon, which continues to decline toward 30¢ to 35¢ a watt by 2020, according to Bloomberg New Energy Finance. The Agora report is even more bullish. “An end to cost reduction for power from solar photovoltaics is not in sight,” the analysts write. That holds even if solar systems see no more technological improvements, a conservative and unlikely assumption.
Last edited by sensij; 02-04-2016, 04:54 AM.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
But as I mentioned above, there are fundamental limits.
MSEE, PEComment
That's true... and yet there might be technology changes that make panels radically cheaper.
Dupont came close to developing a semiconductor paint that could be used to coat a material at very fast speeds. That process would create very cheap solar panels. Problem was the efficiency of that "thin film" solar pv never came around to much. But maybe the breakthrough is just around the corner.Comment
