I think you need to change your boil wire, I will also suggest you to hire solar panel repairmen and ask him to check your whole solar panel system.
solar Water heater boilover - technical
[SIGPIC][/SIGPIC]Comment
>boil wire<
Ok, i did some looking and from what i found (BOIL WIRE) is like putting a hair dryer in the water and use heating element to heat water.THIS IS NOT GOOD PLEASE DO NOT DO THIS PLEASEComment
I think the problem is in the adjustment of the Megagulator, turn the shrew 14 turns clockwise that should solve the problem. If not remove your left nut that should get the reaction your looking for.
Finally some action in this thread.Comment
goeszinta and goesoutta
but frist adjust the goeszinta to make sure that you have good flow, to the goeszinta,after that make sure the goesoutta is working as it should be if the goeszinta is working the goesoutta should also be working.
