DIY solar storage tank
I use 2 layers of Reflectix bubble wrap with the aluminum tape on the seams. Available in 4 or 5 ft widths x 50ft roll. -
Scoring is not likely to have a measureable or noticeable effect on the R value at that tank dia., or more accurately not with a major dia. to minor dia. ratio close to one as that application will be. At that tank dia., and insulation thickness, you may not need scoring at all. I'd try a section and see. I'd suggest making sure the seams on the insulation layers do not coincide, and don't use duct tape - it won't last. Lastly, depending on tank max. expected/design temp., don't forget to consider and account for tank expansion which will be very approx. 3/16" to ~ 1/4" on the circum. for ~100 deg. F. temp. change, so "per-compress" or snug fit the insulation a bit without buckling it.Leave a comment:
Thinking of wrapping a round 8 foot dia. metal wall tank with 1/2 inch foil faced polyiso rigid board to 4 inch thickness. Probably have to score outside face to get curvature on the tank. Question is will R value go up or down with this configuration?
