You sir, have built yourself a bomb. You are just one power or pump failure away. Or some mineral deposit clogging. If you have a fire stoked up in your stove, and loose circulation, it goes boom in 2-30 minutes, depending. You just said in the nuke subs, they naturally circulate slowly, or else they would go boom too.
Wood-Stove Hot-Water system
This is a sticky topic.
Alright I think I've figured it out.... Normal hot water tank, thermo siphon supply into the top of the tank with the return from my floor Y'ed Into it. Return going back to the stove exiting from the drain at the bottom of the hw heater with the suppy to the floor T'ed off somewhere in this area along with the circ pump. If it was designed correct I think it would work well and the suction from the circ would encourage the flow of natural convection. Thoughts?Comment
Toss in a few check-valves to ensure the flow is always in the direction that you intend it to be.Alright I think I've figured it out.... Normal hot water tank, thermo siphon supply into the top of the tank with the return from my floor Y'ed Into it. Return going back to the stove exiting from the drain at the bottom of the hw heater with the suppy to the floor T'ed off somewhere in this area along with the circ pump. If it was designed correct I think it would work well and the suction from the circ would encourage the flow of natural convection. Thoughts?
When you have multiple loops with Y-connections, there is a possibility of water flowing in the opposite direction, without any check-valves.
4400w, Midnite Classic 150 charge-controller.Comment
I will do that. This is the second winter I've had my garage and I've been itching to see my infloor in action. Thanks for your input. If anyone has anything else to add I'm open for options
It only counts if they function perfectly year after year - maybe they will and maybe they won't.
If it is a low pressure system and you can use a vent pipe it would be great.[SIGPIC][/SIGPIC]Comment
When I was a kid we made and placed a copper coil inside the fire box of our wood stove, it pumped water through the coil and into pex tubing in our concrete floor. Even in the teens weather we could burn for four hours in the evening and sleep warm all night. home was earthen berm, super insulated.4X Suniva 250 watt, 8X t-105, OB Fx80, dc4812vrfComment
A copper coil in a wood stove is a time bomb, copper will work harden in the heat, and will fracture easily. Stainless Steel is the preferred material for a heat loop in a stove or heater.
The Wood Heat Organization was formed to support the public in the responsible use of wood energy in the home. We fulfill our mandate by providing reliable information, by conducting research into wood heating-related issues and by representing the public interest in discussions of policies that affect woodburning.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
