Parabolic trough tests
  • netttech
    • Dec 2009
    • 94
    Just an update on my project. My initial attempts at a trough panel failed while trying to create a good-working trough using pvc pipe. I abandoned the idea of using PVC pipe with Mylar because of weight.
    My panel has to be small & easy to handle since I can not leave the panel connected year around. If I have to construct/connect a series of panels to heat (140 degrees preferred) the water sufficiently, fine. At least they will be light-weight.
    I have contructed smaller test troughs using aluminum coil which are near weightless in comparison to PVC troughs.
    I tested the troughs for effectiveness recently & surprisedly the 6" trough performed better than a 7". I expected the reverse to be true. The 6" trough recorded 42 degrees increase (maxed) in 10 minutes. I am using a halegon drop-light to determined the trough effectiveness.
    Later this week I am testing a form to hold the coil in a trough form so I can apply the mirrored mylar. It puckers if the mylar is applied while laying flat, then formed into a trough.
    Within a few weeks I hope to have the panel completed for a true test. I will try to post pictures as I progress.
    jeff
    [url="http://solarpaneltalk.com/album.php?u=2072"]First panel 40 volts, 140+ watts[/url]
  • BuzzBuds
    • May 2010
    • 64
    Being the fact that aluminum if the most heat conducter used in heat sinks and due to the thickness of it. I will also be able to with stand harsher treatment than PVC also
      İs the shape identical for both troughs - parabolic shape? İ agree with you in that it doesn't seem right. Matter of fact it can not be.
      @Buzz - No idea what you meant to say. Please use spell check (this time İ believe you actually did) and then edit afterwards to make sure the words are correct.
      • netttech
        • Dec 2009
        • 94
        Yes, they are very close to the same shape (parabolic - now 4 troughs, 6"wx2 3/4"d). One has a variation only due to the fact I am re-using aluminum coil from my space heating panel. They all have a 'crook-odd-bend', in it but one has a distinct fold close to the bottom of the trough. I'm not sure how it got there. It wasn't noticeable until I made the trough.
        I have 4 troughs built & today spent a good portion of the day building on the frame to support it. I also measured/cut-top-fit the copper tubing. It always take longer to construct the 1st panel.
        I wanted the ability to adjust the tubing (up/down) to fit the focal point. My carpentry is not perfect so I wanted so lee-way, for that imperfection I possess. I came up an idea I believe will work. I will solder the copper & finish the frame in a couiple of days.
        Jeff
          Good luck Jeff and we will be following your progress closely!
          There are two applications that really interest me:
          1) Parabolic troughs for higher water temperatures
          2) Solar air heater
          Both can be applicable for me and my location plus don't have to cost an arm and a leg.
          İ liked the comment about carpentry! İ much prefer steel as for home projects normally it is possible to modify lengths or shapes as required.
            Hi Jeff - Here is the site of a guy who has built parabolic troughs - seems to be quite a resourceful and capable fellow!
            BENTO11 adalah platform media digital modern yang menyajikan wawasan kreatif, tren teknologi, ide inovatif, serta insight dunia digital untuk membantu individu dan brand berkembang di era online yang terus bergerak cepat.
            • netttech
              • Dec 2009
              • 94
              Test Results from my panel
              Russ, that was a good link. Thanks
              In june I finally finished my 1st parabolic panel & tested it. It weighs about 20lbs, 30"x56". The 4 troughs are 6 3/4"w x 2 3/4d. It creates a sustained 12-14 degree increase in water temp at 1-2gpm. I was using a tub of water (6 gallons) for the test, so the pool of water temperature increased also. The maximum sustained water temp was 118 degrees, with the pooled water at 93.
              I am in the process of making a 2nd panel to connect in series. I suspected it would be necessary for at least 2 panels the desired water temp when I started this project.
              Lessons learned: The trough should be wider & 'shallow'. I emphasised shallow because it appears on a deep trough the top portion of the trough, will not reflect onto the copper tubing. I used a common Laser to confirm the focal point/location of the tubing. About 1/4" on the top portion of the troughs would not reflect on the tubing. When I tried to adjust the tubing heighth, I would loose other reflectability.
              The 2nd panel will be the same overall dimensions, with shallow troughs. I will try to post a picture of the finished panel.
              Jeff
                @ Jeff - Well done and am happy to hear of your progress.
                Best of luck on the next step and please let us know how it goes once again!
                Russ
