Just an update on my project. My initial attempts at a trough panel failed while trying to create a good-working trough using pvc pipe. I abandoned the idea of using PVC pipe with Mylar because of weight.
My panel has to be small & easy to handle since I can not leave the panel connected year around. If I have to construct/connect a series of panels to heat (140 degrees preferred) the water sufficiently, fine. At least they will be light-weight.
I have contructed smaller test troughs using aluminum coil which are near weightless in comparison to PVC troughs.
I tested the troughs for effectiveness recently & surprisedly the 6" trough performed better than a 7". I expected the reverse to be true. The 6" trough recorded 42 degrees increase (maxed) in 10 minutes. I am using a halegon drop-light to determined the trough effectiveness.
Later this week I am testing a form to hold the coil in a trough form so I can apply the mirrored mylar. It puckers if the mylar is applied while laying flat, then formed into a trough.
Within a few weeks I hope to have the panel completed for a true test. I will try to post pictures as I progress.
jeff
jeff
