Solar Pool Heating with Irrigation Hose Help
If you believe those reviews then have fun - 99% are made up BS - NO panel will work the way they are saying.
Try youtube - they are full of baloney like you want to hear.[SIGPIC][/SIGPIC]Comment
I run my small 12 Watt pump off a 36 Watt homemade panel. I use it for pumping rain water from my barrels to my garden. Works great.
As noted before just make sure your panel produces enough current (Amps) to run your pump. Don't worry once you get it set up you will get a lot of pleasure seeing a system that you put together doing what you want it to. I know I do.Comment
