Solar Pool Heating with Irrigation Hose Help
It would typically use the pool filter pumpNABCEP certified Technical Sales Professional
Here is another black plastic pipe version http://rimstar.org/renewnrg/solar_po...ter_diy_fp.htm
or http://www.mmattera.com/bin/Solar_Pool_Heater_Coils.jpg
The rimstar site has the calculations[SIGPIC][/SIGPIC]Comment
I think I decided on the pump:
http://www.amazon.com/Rule-Submersib...+water+pump+dc
The pump is 24watts. I'm going to ask a dumb question. Can I use a 30w panel or should it be higher? Anything in particular the panel should have?Comment
Depends on if that pump can be ran solar direct. Not all DC pumps can.I think I decided on the pump:
If possible find an older style solar panel that is designed with 28 to 32 cells instead of the standard 36 cells for 12V. The lower VMP and VOC will help with running solar direct. Instead of just watts you need to make sure the amp (IMP) rating is higher then the requirement for the pump.
WWWComment
These are the stats on the pump:Depends on if that pump can be ran solar direct. Not all DC pumps can.
WWW
Fuse Size: 2.5 amps Amp Draw @ 13.6 Volts: 1.9 Amp Draw @ 13.6 Volts: 2.5
There's also one with less power and the following (but I prefer the one above):
Fuse Size: 2.5 amps Amp Draw @ 12 Volts: 2.1 Amp Draw @ 13.6 Volts: 2.5
Can I make this work? Can you recommend an exact panel?Comment
That pump will only lift about 5 feet with any kind of flow. Check the pump curves against your static and vertical head before doing anythingThese are the stats on the pump:
Can I make this work? Can you recommend an exact panel?NABCEP certified Technical Sales Professional
The Rule 500 should have 6.7 Feet of lift. I don't need much lift at all. I'll be putting the setup on a hill near the pool. I won't be putting it on a roof or anything.Comment
can't answer that as the pump is not designed to run from solar only
Look into solar fountain pumps you may have a better shot of finding something.NABCEP certified Technical Sales Professional
I see a lot of reviews that state the smaller one is used for solar:
http://www.amazon.com/Rule-24-Marine...ords=rule+pump
Can you recommend a solar fountain pump then?Comment
google is your friendI see a lot of reviews that state the smaller one is used for solar:
Can you recommend a solar fountain pump then?NABCEP certified Technical Sales Professional
So you want me or us to find everything for you. Sorry you get what you pay for and last time I checked no one here gets paid to do everything for you.
I sent you in the correct direction what more do you want me to do. Come and install it for you?NABCEP certified Technical Sales Professional
