I'm interested in modifying a Paradise GL23112 solar powered workshop light that powers a 6v 10w florescent bulb and charges a 6v 4ah lead acid battery. I'd like to power led lights and recharge a better battery choice. As far as I can find the panel is a 1W panel. Can this be done?
shed light kit mod
1 watt panel? You can fart more power in a day than a 1 watt panel will generate in a week.MSEE, PE -
Likely not, as sunking said, a 1 watt panel is silly small. I think the littel panels used by VW for car shipping, can be had on ebay pretty cheap, and their 12V is a more standard power for many lights.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
