Will solar path lights actually hold up in south Louisiana humidity?
  • adrianfen45
    • Oct 2026
    • 11
    I'm in Baton Rouge and finally getting the backyard sorted, mostly low-voltage path lights along a walkway and a few spots on a new patio set up. Everything I read online says solar stake lights are the easy move, no wiring, but I keep hearing about moisture getting into the battery compartment and the units dying in a year or two. Between the humidity and the afternoon storms, I don't want to buy twice. The other unknown is whether a light near a patio chair gets enough sun with the house shading part of the yard after about 3pm. Anyone in a similar climate running basic solar path lights through a full rainy season? What actually failed first for you, the panel, the battery, or the housing seal, and did you do anything at install time that kept them alive? Mostly trying to decide whether cheap and replaceable beats spending more per fixture.
    • 15211
    solar path lights last about a year usually due to the panels getting too much heat. at least that is what happened in Brooksville Florida
    • LeonidGorok
      • Nov 2026
      On what usually fails first: the battery, by design. One path-light maker's manual says the included rechargeable cells usually last about two years and tells you to swap in a standard AA Ni-MH or Ni-Cd rechargeable of at least 800 mAh. So pick a fixture with a battery compartment you can open with the lens twisted off, and plan on replacing cells rather than the whole light.
      For the moisture worry, look for an IP number on the box rather than the word waterproof. The IP code comes from IEC 60529. IP65 means dust-tight and protected against water jets, and IP67 also covers temporary immersion, 1 m for 30 minutes, which matters in a spot where water pools after afternoon storms.
      On your shade question, that same manual says to put the light where it gets full, direct sun each day and keep the panel clean. It also says that other light sources nearby, such as a patio lamp, can keep the light from switching on at night. So a fixture beside a patio chair has two problems, the shade after 3 p.m. and any other light spilling on it.
      Before buying a full set, I'd put one or two in the planned spots for a week and see how long they run each night.
