Approx. Cost for 10m Wide, 1KM Solar Roof on Road
Installing solar panels over the roads is not very practical.Leave a comment:
Plus it is a large commercial installation which is totally out of the scope of all here - except possibly Sunking. This is typical for India - try to get someone to do your work for free.This is really the wrong place to try to get a question like that answered. A lot will depend on the road, local labor and material rates, the exact design of the system, etc. This is a significant engineering project, and a bunch of random yahoos on the Internet won't have a clue about the answer.Leave a comment:
I agree.
Don't forget about the cost to install the required lighting under the solar roof. You would now have a tunnel and not be able to light a large area of the road with the standard tall 1000 watt pole mounted fixture so it would require many more lighting fixtures to get the appropriate foot-candle level for drivers to safely see other vehicles.
There probably would be all types of requirements (safety & construction codes) set by the Department of Transit (or whatever they are called in other Countries) for the installation and maintenance of that system which adds costs to the project.
Just too many variables to consider to pin down an accurate cost /KM for a solar roadway roof.Leave a comment:
The solar part would cost no more than putting it on any flat roof. What we can't estimate is the structure that it would take to span the road to support it.Dear All,
Thanks for presenting the issues behind solar roads, but just for a time, if somebody plans solar roof on roads, than what would be the cost per KM,
You all are experts in this industry, so kindly give me some rough idea of Approx cost.
Thanks in Advance
Ashish
WWWLeave a comment:
Guest repliedApprox Cost Please
Dear All,
Thanks in Advance
AshishLeave a comment:
That 5$ per watt is just a number some fool at Gizmag pulled out of his backside (or some Belgian did). I quit Gizmag long back due to their loony reporting.The real issue here is cost. There are lots of cheaper places to put solar arrays than over roads.Consider that a solar array over a road needs to be elevated above the traffic on a structure strong enough to withstand windstorms, snow, etc., and in a way that it won't cost huge amounts of money to fix every time someone crashes into a pole, and you begin to appreciate the challenges. That solar railroad, for example, cost about $5/watt according to the article you linked, which is substantially more expensive per watt than putting the same number of panels on the roof of a warehouse.Maybe once all the suitable flat roofs, parking lots, billboards, etc., have been covered in solar panels, then roads would be worth considering.Leave a comment:
The real issue here is cost. There are lots of cheaper places to put solar arrays than over roads.Dear Russ,
Solar Panels are above Roads, which is under government control (i think), so there will be no issue of land, permits, etc.
for structure & interconnection, cost is the major issue, which can be provided by advertisers,
Check the below link once
http://www.gizmag.com/solar-rail-tun...mpleted/18881/
For the Gizmag thing - Say 50,000 m2 of panels operating at 10% efficiency (which is very high considering orientation) for an average of 3 sun hours per day (it is Belgium and that may be excessive) 365 days a year = 50,000*.1*3*365/1,000 = 5,475 mW generated. Maybe 150,000$ to 300,000$ US worth of power generated per year - for that investment wow NOTLeave a comment:
Another wacko idea with government money carrying the day. All this is silly green BS. The cost of the land is not that big of a deal.Dear Russ,
Not one of those 245 watt panels is oriented in an optimal direction - they are far less than what they should be - cleaning is a really big deal.
The advertising is eye candy for the green fools to support.
All in all, really a stupid idea.Leave a comment:
Guest repliedDear Russ,Explain why BS is BS? In detail? No thanks however - To start with land for solar farms is not the problem - it is the least of the problem. This idea comes up with a couple of very small plus points and lots of negatives.
Most of your costs will be local ones - land, permits, structures (major), interconnections and on. The panels will be a small part and the commercial size no one here can comment on. You would have to spend some money and talk to an engineering firm.
The roof of a two mile stretch of tunnel over Belgium's high speed rail line has been fitted out with 16,000 solar panels to provide power for trains running through Antwerp Central Station and the surrounding railway infrastructure. Solar solution provider Enfinity says that about 4,000 trains per…Leave a comment:
Most of your costs will be local ones - land, permits, structures (major), interconnections and on. The panels will be a small part and the commercial size no one here can comment on. You would have to spend some money and talk to an engineering firm.Leave a comment:
Guest repliedLeave a comment:
Congratulations on finding one really useless idea. The advantages listed are not advantages at all really.Leave a comment:
