This is the plug and play arrangement that is not legal - right?
They add instructions to allow the owner to do ir more correctly and safely if they want to - difficult choice to make when most people buying them will have no idea. Rather than pay an electrician to make a more proper connection most will leave it.
With just a couple of panels it will never spin the meter backwards.
Easy solar?
Without an insoection from AHJ the POCO will not care if they have new meters. Any excess he generates he will be billed as if he used it.Leave a comment:
Sure LOOKS like a polycrystalline panel to me........
But that aside, since these do seem to have UL listing, it's gonna be interesting how the use of these spread, and how the power companies will take it.
Of course, too, you can buy a 240w Solarworld MONO crystalline panel now for $380, and an M215 Enphase inverter for $150, so the combo of that is $530. It would be 240v output, not quite as easy at the "plug n play" 120v version these guys are offering, but it's also 300 bucks less per panel ( less the mounting kit they throw in, which doesn't look like 300 bucks worth of mounting kit ).Leave a comment:
Be interesting to hear from Sunking and others about the legality of this arrangement.
Solar panel "kit" comes with everything you need to start receiving FREE energy from the sun. The "kit" come with the following: (1) 240 watt UL approved MONO crystalline solar panel, (1) 120 volt AC UL approved micro inverter, (1) deck mount system complete with all stainless steel hardware to assemble (about 30 minutes), (1) 120 volt male plug attached to the inverter output plug.
TO MEET NEC CODES WE RECOMMEND THAT YOU INSTALL A GFDI RECEPTICLE WITH A CONTINOUS USE COVER. WE ALSO RECOMMEND THAT YOU USE A DEDICATED 120 VOLT LINE CONNECTED TO YOUR ELECTRIC PANEL VIA A 15 AMP FUSE OR BREAKERLeave a comment:
120 volt AC plug and play
Hey...just to let you guys know I just bought a few panels from a company that plugs into your outside plug. I got the 120 volt version that hangs on my deck. The solar panels already have the microinverters attached. So all you have to do is bolt together the deck mounting system and you are all set. It is so cool, in about a hour I had the rack put together and hanging on my deck. The racking is made of aluminum angle and has all satinless steel bolts.Then I put in an AFCI breaker in my panel and made sure that the line was dedicated to just the outside plugs on my house. Nothing is drawing off these plugs but the panel. I will put the recommended cover on soon, have to go to Home Depot to get one. I also plugged in a kill A watt meter so I could see how they were working. After plugging the 2 panels together I plugged in the end plug to my house outside recepticle/kill a watt. These are UL approved grid tie microinverters it takes 5 minutes for the house 120 volt power to turn on the inverter.....then the kill a watt shows it is working...I am getting about 418 watts with the panel adjusted at the right angle. There are several adjusting holes on the rack....it fits very nicley over my railing on my deck, very secure. What can I say....they actually work as advertized. by the way the company is called spinrayenergy.com/products/deckpower120.html
MikeLeave a comment:
Before you buy any of this Grid-tied inverter, your house must have net meter or meter that is reversiable. Otherwise, Grid-tied inverter will not work the way you want.Leave a comment:
Thanks for the response! Ok, so you seem to know what you are talking about so i appreciate the advice, but the other day i was searching through solar panels on amazon and found a company selling what they claim is a 120-volt AC plug and play panel. I don't know much about solar (obviously) but they say the panel can be plugged into a standard outside wall outlet because it has a UL compliant micro-inverter attached which shuts off in the event of a power failure as to not backfeed, is this true? Has anyone heard of the company (SpinRay Energy), i'd like to know more?
"Get a UL/TUV listed Panel with an AC Inverter"
Notice it doesn't say the inverter is UL/TUV listed. Just the panel.Leave a comment:
Interesting info...
Thanks for the response! Ok, so you seem to know what you are talking about so i appreciate the advice, but the other day i was searching through solar panels on amazon and found a company selling what they claim is a 120-volt AC plug and play panel. I don't know much about solar (obviously) but they say the panel can be plugged into a standard outside wall outlet because it has a UL compliant micro-inverter attached which shuts off in the event of a power failure as to not backfeed, is this true? Has anyone heard of the company (SpinRay Energy), i'd like to know more?Leave a comment:
Amazon.com sells inverters that plug directly into a standard outlet. I do not recomend it. They are not ETL or UL compliant. The invertrs are not clean sin wave power either. This means it causes numerous issues.
Dirty AC power causes dirty surges, shortens the life of house hold appliances and worst of all can literally catch nm conductor on fire within the walls of your home!!
No inverter should be installed without proper installation of using a backfeed breaker supplied at the main panel. main panels can take the current while a typical outlet cannot.Leave a comment:
Hi Ronald - Welcome to Solar Panel Talk!
There is no legal product like this available in the US. There are some shysters selling products like this on ebay and other locations but that is a no-no for many legal and safety reasons.
As Sunking pointed out all panels are DC and a little 'thingy' called an inverter converts the DC power to AC.Leave a comment:
You are dreaming. There is no such thing a an AC panel. All solar panels are DC. Some maybe made with a built in inverter but you cannot escape regulations. There will never be a code compliant GTI that you can plug into an outlet in the USA. That only exist in Ronald McDonald FAIRY TALE LANDLeave a comment:
Easy solar?
Hey, newbie here! Anyone heard of AC panels that can plug directly into a regular electrical outlet? I want to go solar but don't want the expense of an electrician
