I was going to mention the 4200 btu/h that Ampster just posted. Where are you getting the 600W number from? Maybe a different water heater? I can't find many of the water heaters that specify the rating on their heat pump or even their power requirement. They just give an amp size for the breaker which doesn't tell you anything about the heat pump.
In your second paragraph I think you are explaining using DC from panels to heat water? I guess you can cut the inverter losses but other than that I don't see what else you'd gain. But then I am not a solar expert so I could be missing something. The problem with me doing that is that this second solar array I am installing for heat is located about 250 ft away and I kind of need to backfeed the AC power into my main house panel for this plan to work. Otherwise I have to run another set of DC wires and can't use my existing buried AC feed to the shop.
The Rheem HPWH is actually not that expensive. I think they start around $1200 for the 40 gallon model with a $200 tax credit or rebate.
My other option I have considered are using solar collectors to heat water but has some disadvantages of the additional plumbing outside and the collectors are very expensive. It will cost about what I would spend on the solar setup & water heater just for a single vacuum tube solar collector that provides maybe 15k btu/h, and I'm not even confident in that number. With my panels and 6kw inverter I can provide about 17k btu/h using the HPWH. My total investment will be around $4000 for the HPWH setup and about $1k of that was already spent on the 5kw of panels. The rest is the heater, inverter and mounting hardware. Floor piping and all the plumbing and wiring is pretty much all in place.
It will be an interesting experiment for sure, and will qualify for the 26% tax credit. So at a net $3k investment I figure it will pay for itself in gas savings in about 3 years. Not even including the additional power in the summer when we don't need the heat, and if I can find a way to use the HPWH for domestic hot water during the non heating months it will save on hot water too.
Now all this being said, I would love to find someone who has actually tried this. I'd hate to do all the work and find that I was really only getting 2000 btu/hr or something less than what they advertise..
