1. If you bought solar panels from a manufacture like Sharp or Kyocera you will be able too buy more panels of the same make and model to add on. If that is the case you just reconfigure them if necessary for the higher voltage by re-wiring them. If not Flea Bay your old ones, buy new ones, and learn your lesson.
There is another option of running two separate panel arrays with each its on Charge Controller, but it is expensive.But hay you are off-grid, money is no object, you have lots of money to burn.2. Assuming you bought a good MPPT controller like a 80 amp MPPT you are set already other than some switch or software options/changes in battery voltages A 80 amp MPPT controllers has a input limitation of:
1000 watts @ 12 volt battery
2000 watts @ 24 volts
4000 watts @ 48 volts
3. Batteries are questionable and depends. If you have say 2 12 volt batteries operating in 12 volts parallel, just wire them for 24 volts. But most likely at that point you are likely ready to upgrade/replace the batteries and you will need twice as much capacity.
4. Inverter you can sell the old one on Flea Bay to a sucker, or put an eye bolt on it, fit it with a rope, and use it for a boat anchor on your fishing boat along with those expired batteries.
