First thanks to everyone here as I've learned a lot over the last several weeks about the intricacies of solar. I'm in central NJ and looking at getting solar on the house. We did the NJ Clearn Energy program 5 years ago where they replaced AC, furnace and water heater with very efficient items and also re-insulated the attic and garage on our almost 20 year old home (just under 2,000 sq ft). Our usage was pretty low but we got a Tesla M3 a little over a year ago so usage is now up to 11,140 kWh for rolling 12 months. Our usage is somewhat sporadic as wife does pottery as a side job so we fire the electric kilns at non-set intervals so sometimes we have months at 1300 kWh but average around 950 kWh.
When I do the PVWatts for 1kW system (thanks JPM) it shows 1360 for my location so if I divide that by my 11,140 usage I get 8.2 kW. From my understanding this would be the correct size for my needs. However, most of the proposals I am getting are higher, like around 9 kW. Does this take into account some loss/degradation or are these just oversized ?
I also have 2 proposals that I like best as they come from highly rated installers. They both gave prices for Tier 1 (Jinko and Qcell) and high end Panasonic. The part that is confusing me most is that 1 is using Enphase micro-invertors while the other uses SolarEdge Optimizer and SolarEdge inverter. The prices are close so I'm trying to figure out what option would be best. The Panasonic model is VBHN325KA03. Here are details (all cash prices before tax credit):
Green Power Energy (GPE): 9.1 DC kW STC, First Year Output: 11,358 kWh 28 panels (see below), 28 SolarEdge P400 Optimizers, 1 SolarEdge SE7600H-US
QCell: 9.1 KW $26,390 ($2.90/watt)
Panasonic: 9.1 KW $28,210 ($3.10/watt)
Exact Solar: 8.775 kw DC STC, Annual usage: 11,140 kwh 27 panels (see below), 27 Enphase Micro-Inverters
Jinko Eagle 60M 8.775 kW $25,401.60 ($2.94/watt)
Panasonic: 8.775 kW $27,290.25 ($3.11/watt)
I read what I could with the micro-inverter vs optimizer but really not sure which one is best suited for my environment. Roof is South/southeast facing and no shade and I attached a picture from one proposal (both are similar except one has 6 panels on garage and other has 8). In the picture, south is down but not marked.
For the panels themselves, I know that the consensus here is that the Tier 1 panels are all pretty similar in performance and the Panasonic (or Sunpower/LG) are not usually worth the extra cost. Even though the Panasonic warranty is 25 years I realize that the chance of the panel failing is pretty low. However, wife feels better going with Panasonic and at only $1300 (after taxes) more I'm leaning towards that right now.
For what it's worth, I'll be getting roof replaced since it's 20 years old and would be replaced soon anyway. My last year cost of power was ~$1600 and estimate SREC at $180 (I know this is a guesstimate) so I'm looking at savings of about $1600 + $1800 = $3400 a year. With Panasonic panels cost after taxes is $19,100 - $19750 ($19,425 average) so looking at 5.7 years for return on investment which I think is pretty good.
I would appreciate everyone's thoughts on the Enphase micro-invertor vs SolarEdge optimizers plus any other comments you have. Plan would be to put optimizer in garage next to panel as no basement. We already have NEMA 14-50 for Tesla charging so don't need that option on the SolarEdge inverter if anyone is thinking that. Luckily we had existing wiring due to the kiln
Thanks in advance!
Thanks in advance!
