Coming Soon to NJ - 12.35 kW Hanwha DUO-G5 + SolarEdge Inverter/Optimizers by GPE
Wow quite the treasure trove lol. Damien did tell me to look where the dumpster sat on the street after they hauled it away and I didn't find any. I looked several times in all my paved areas (driveway, paver patio and side paver walkway) and found just a single nail. I did not comp through the grassed areas though, although the crew did that with a similar looking magnetic sweeper. -
Correct, GPE spec'd my (and I'm sure sunpoweredev the same) system using Quick Mount PV's L-Mount Flashing Foot which are 9" x 12" aluminum. As it was explained to me the installers also apply gue to the underside of the flashing panel before laying it down as an extra failsafe so 1 hole or 10 I don't see water working its way back under the flashing AND glue on top of being already protected from direct driving rain do to the panel above it.
If the installers are even ~10% competent they're using flashfeet. The flashing is ~12" wide so even if they miss the rafter by a few inches and have to drill another hole all the holes are covered. You could probably cut a hole under the flashing and it still wouldn't leak. The bolt penetration is raised AND sealed. The solar anchor may actually be LESS likely to leak than the rest of the roof since it's somewhat reinforced.
I've mounted >300 solar feet... no leaks. Several extra holes...
https://www.youtube.com/watch?v=-qN5dwEumCM
FWIW, one thing of many I learned while watching (mostly from the ground) the ~ 130+ arrays that have so far been installed in my HOA is how many holes get drilled in roofs that seem to go "thump" about 3-5 seconds after the drill starts, with another hole immediately drilled and located in a place that appears to be immediately adjacent to the hole just drilled. If folks knew how much daylight and empty space is being created in their roof deck, or its longer term consequences, they might be concerned. I always suggest that my neighbors sit on their roofs, out of the way during installs and watch, and then bitch when they see what goes on (or doesn't go on) during an install. Of course no one does. Of all those installs, there's probably ~ 100 roofs with ticking leak problems.
No issue at all. I tagged all you local/GPE guys for a reason and it's been great going back and forth, sharing info and working through our questions and concerns.
Plus since your system is basically the same size and equipment (besides the panels) and by the same installer it's all relatable in my book.
So about that magnet roller from Amazon...just got it today and took it out for a quick spin in the rain (front walkway, driveway and back walkway) and look what I found!
Highly recommend for anyone with a recent or pending roof job...as clean as it might look to the eye you'll be shocked what this sucker will pick up right under your nose. Spots that seem to hide the most treasure were the walkway edges and my stone beds in the front of the house. 2-3 nails were on the driveway around the dumpster they pulled this morning.
Master Magnetics - Magnetic Sweeper with Wheels, 14.5"
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1Last edited by NJturtlePower; 06-19-2019, 09:07 PM.Leave a comment:
6 year payback period is awesomeGreetings all, my name is Tony, a.k.a "NJTurtlePower" on this and many other forums, and I'm excited to share the details for our soon-to-be installed solar system here in Flemington, NJ.
I've been lurking here for a few weeks/months during my initial solar research phase and now that our system design is finalized, financing is settled, and the utility interconnection plans are approved, it's time to share all the juicy details and how this all came to be.
First, I would like tag a few forum members that I discovered browsing and searching the forums here that are from my area (NJ) and/or are related to our installer Green Power Energy. In some way or another I may have used your solar experiences, system advice or comments in my own planning, so thanks!
J.P.M. jordgubbe sunpoweredev JSchnee21 flowing macaddict
I guess you can say I've been interested in solar for many years now and even did my senior thesis on the subject during my undergrad at NJIT. Last year kinda got me thinking hard about solar again after the long awaited delivery of my Tesla Model 3, as well as the deadline and changes to the NJ SREC program. So, I started where many of us do, Google...which led me to EnergySage and eventually a few site visits/consultations with a handful of local vendors as well as Tesla Solar, and as they say, the rest is history.
Over the course of my journey I dealt in detail with Tesla, Sun Run, Evoke Solar and Green Power Energy. As the title suggests, I settled with GPE in the end, but in one way or another tried to use all the quotes, system designs and Q&A sessions, etc. from all the vendors in some way or another in the decision making process. If anyone has any specific question about the OTHER vendors or their quotes feel free to reply, but for sake of time and boredom from reading my lengthy drawn out posts, I'll just keep my focus here on GPE and our soon-to-be-built system.
As many others have already attested to, both here and on other mediums online, GPE has been top notch in all phases of this project to date. My initial and main contact at GPE has been Tim DeSevo, but I also dealt a bit with Sara Thorpe from the Design Team. Basically all my communications have been via EnergySage messages or direct email besides the site survey (Mark Taylor) which I prefer overall. Tim's responsiveness and patience (in all my endless questions/concerns) has been all I could ask for as he would literally respond within 2-5min of every exchange. GPE's partner roofer (we'll get into that later) is C. Costello Roofing out of Ventnor City, NJ and they have a very similar reputation as GPE, and so I'm told, the reason they have decided to partner up on projects as needed. Damien Correa has been my contact at Costello and has also been super helpful, honest and again very patient getting back to me on anything I asked of him and I'm very much looking forward to dealing with their end of the project hopefully in the next 2-3 weeks to get the ball rolling.
Energy Usage:- Utility Provider: JCP&L
- Current Utility Rate: $0.1506 per kWh ***UPDATED June 19' rate***
- Pre-EV Charging Annual Usage / July 2018 Data: 9,385 kWh
- Current Annual Energy Usage (Estimate): 13,850 kWh (EV charging for about 10-months via NEMA 14-50 outlet / Approx 10K miles driven per year)
- Nameplate: 12.350 DC kW (STC)
- First Year System Output (Estimate): 14,354 kWh
- Lifetime System Output (Estimate): 273,850 kWh
- Solar Panels: 38 X Hanwha Q-CELLS Q.PEAK DUO-G5 325w Modules
- Optimizers: 38 X SolarEdge P400
- Panel Layout: 3 Arrays - 20 Panel (South) / 12 Panel (East) / 6 Panel (West) *See Attached/Below
- String Layout: 3 Strings of 13/13/12 *See Attached/Below
- Inverter: 1 X SolarEdge SE11400H-US
- Mounting/Flashing Hardware: IronRidge XR10 Rail / Quick Mount PV (QMLM/QMLM-2)
- Total System Cost: $36,590
- Price Per Watt (Pre-Incentives): $2.96
- Financing Partner: Sungage Financial
- Financing Terms: 18-Month 0% APR for FTC Portion / 2.99% APR for 60-Months on Loan Balance
- Monthly Payment: $460.01
- Return on Investment (ROI) Estimate: Approx. 6-Years
Roofing Project:
So this was not a part of our original plan, but unfortunately a reality of our current situation. As the more recent owners of an early 1980's home (approx. 2,400 sq ft) we knew little about the history of the roof besides the current condition explained to us by GPE/Costello as well as the other guys who conducted physical site surveys. After a little further digging I was able to find a Sellers Disclosure document that listed the age of the re-roof (2nd layer) and by adding the time we have now owned the home puts it at approx. 21-years. The re-roof workmanship/install is also questionable at best, so to eliminate the concerns and to avoid potentially spending several thousand in extra labor to remove and reinstall the solar system a few years down the road; we are tackling this project head on with help from Costello Roofing. They will be installing a new 30-Year Tamko architectural shingle roof in preparation for the GPE solar system, all rolled into the existing Sungage Solar loan which is super convenient and affordable given the 30% Federal Tax Credit. Costello's roofing pricing was already highly competitive regardless of the FTC based on others who have looked at the roof due to the added expense of the near vertical "barn style" sections of our 2nd story.
Current Timeline:- We were given the green light to our solar design and permits last week (3rd week of May 2019) by JCP&L.
- Costello Roofing Roofing Install: *** COMPLETE - 6/14 & 6/15 ***
- GPE Solar System Install - Date TBD
- Utility Inspections / PTO: Date TBD
Well, that's the plan as it stands guys.... feel free to comment, question and critique. I'm interested to hear updates from recent GPE install owners and/or any last minute details to be on the lookout for with my install coming up soon as well. If I left out any pertinent details let me know, as I will be updating this thread as the project evolves.
Thanks again all!
No it is not the RGM, the RGM is part of the inverter (though a similar looking part inside of it).
Is that not the RGM add-on for the Inverter? Guessing it doesn't come pre-installed? ButchDeal
You didn't add a Consumption meter did you?Leave a comment:
That is a consumption meter. make sure they install it correctly (some installers are lazy and will just leave it in the box).Just saw this box which wasn't on the packing list. What does this electric meter do? I saw the spec sheet on SolarEdge website which says this is an "energy meter with ModBus connection" but still unsure what its function is.
Edit: wait a minute, does it function as the consumption meter? ButchDeal may we pick your brain once more please
https://www.solaredge.com/sites/defa...umption_na.pdf
SE.JPGLeave a comment:
Not sure if it's the RGM addon. Perhaps? But per that SolarEdge PDF it monitors consumption. No I didn't buy the consumption meter.
BTW if I'm clogging up your thread please do tell. I just thought maybe you find this informative.
Is that not the RGM add-on for the Inverter? Guessing it doesn't come pre-installed? ButchDealJust saw this box which wasn't on the packing list. What does this electric meter do? I saw the spec sheet on SolarEdge website which says this is an "energy meter with ModBus connection" but still unsure what its function is.
You didn't add a Consumption meter did you?Last edited by NJturtlePower; 06-19-2019, 01:42 PM.Leave a comment:
SE.JPGLast edited by sunpoweredev; 06-19-2019, 01:36 PM.Leave a comment:
Yeah the way that the operations guy Mike S. was responding to me is that they would prefer to add the cheap external RGM regardless of the RGM inverter option. I'm not opposed to that, and if anything will add a layer of redundancy to the system at no additional cost to me, so have at it.The crew is here now installing the racking. I asked the guy if the RGM inverter means there wont' be a separate RGM, he says when the team comes and actually does the electrical work and the line tap, they will install a separate RGM. Perhaps he doesn't know about the switch to the RGM inverter. I guess I will find out in the next couple of days.
Not a good feeling hearing them drilling all over the new roof.
I hear you about the roof knowing they'll likely be adding about 100 penetrations between the racking and wire runs, but fingers crossed and faith in a careful, competent and accurate install.
I'm going to try and spot check my attic today actually, because if they are any faults with my new roof this rain in the past two days should surely show it by now.Leave a comment:
Yeah, because 100 out of 130 have leaks?! Wow. I took a peek up in the attic and it was complete darkness. Good sign perhaps
You're welcome. But I seem to detect a note of sarcasm in your response.
As I wrote, take it FWIW. Just relating what I've seen over the last 12 years. Maybe it's of no use. Maybe it's of some current use. Or, maybe it'll be a useful clue some rainy night in the future.
As usual, and in any case, take what you want of my stuff. Scrap the rest.
As usual, and in any case, take what you want of my stuff. Scrap the rest.Leave a comment:
Thanks. I feel better now
