  • craigmandu
    • Apr 2019
    • 4
    Need help understanding options
    So I've decided to install a 10 kW array on a ground mount in my yard. Looking at what is online I have some quotes for equipment and am wondering some things.
    Right now I'm looking g at 4 rows of 7 panels, each panel is 360w, and puts out roughly 39vdc at 9.9 amps. I was thinking of 2 sunny boy inverters at 5 or 6 kW each.
    I assume the best way to configure it would be to connect each row in series, giving me approx 280vdc at 9.9 amps. Here are where my questions start.....
    I could combine those strings and run one set of wires to the controller location, but that would up the amps to roughly 40....the sunny boy inverters have 3 inputs but each is limited to 10 amps...so can I run a single cable set to them, then basically run the inverters inputs in parallel on the controller side? Or would it be better to run 4 sets of independent string connections to the inverters? Keep in mind I will probably need to put in dc disconnects for code purposes, so one dc disconnect is obviously easier to manage than 4........
    Thoughts? Should I instead look at a single inverter setup?
    Thanks for any advice given
    Craigmandu
    • 5199
    If you expect to have much snow, go to Solar Panels for your Home, Grid Tied Solar PV
    and read the first STICKEY Snow Tolerant PV Mounting. Bruce Roe
    • craigmandu
      • Apr 2019
      • 4
      This is in Virginia beach Virginia, not much snow activity here....however I do have a single ground mount design using 2" schedule 40 pipe. Buried in concrete to 54" .... That's more for wind considerations, using ironridge xr1000 railing.
        • 14926
        Do you have any jurisdictional requirements for system mechanical design as relates to wind considerations ?
        • craigmandu
          • Apr 2019
          • 4
          Unsure at this time, I have begun talking to permit office about it. Vendor has indicated design is sufficient for 120mph wind considerations
            • 14926
            You believe a vendor right ? Ground mounts are pretty individualized. The vendor is qualified to stamp and sign off on a wind design ?
            He may be correct, but I'd make sure, as you are doing that all code requirements are met, including those for external loadings. Get it in writing.
            • craigmandu
              • Apr 2019
              • 4
              I have no intention of purchasing g prior to permits being approved. Which I am investigating right now. I have plenty of time, just want it online by December 31
              • macaddict
                • 132
                Interesting question. Following...
                https://pvoutput.org/list.jsp?userid=59404
