  • sevensixtwo
    • Jan 2019
    • 4
    Want expert comparisson on two batteries.
    Hi. My expected load is about 1000kWh per day. I am going to wire two 100W panels in parallel to a 10 amp current controller, or maybe a 15 or 20 amp in anticipation of a later expansion. I am going to use two batteries in parallel, and a 400W inverter. I live in a sunny southern state (I hope!) and I have a nice unshaded spot in my backyard. I am considering the following two battery models, and I want an expert to please the critic the relative merits. It can be rainy here so I want a second battery for more amp hours, which one shoudl I get two of?
    EverStart Maxx Lead Acid Automotive Battery, Group H8
    EverStart Maxx Marine Battery, Group Size 29DC
    My feeling is that the 29DC model is the one I want, because it says "DC=Deep Cycle" but sometimes the manufacturers use tricky model names and I see "cranking amps" instead of "amp hours" for both when I don't really need cranking amps to power my computer.
    Originally posted by sevensixtwo
    Hi. My expected load is about 1000kWh per day. I am going to wire two 100W panels in parallel to a 10 amp current controller,.......
    Well, there's your first problem. I hope it's just a typo.
    Batteries with cranking amps, are generally not deep cycle batteries..
    A pair of 6V Golf Cart batteries in series would give you 12V @ 200AH. You could parallel another series pair and get yourself up to 12V 400ah, with just $400 of golf cart batteries.
    2nd problem is 200w of PV is not going to be enough to recharge.
    200ah of batteries needs 20A to charge 400ah needs 40A charging current. Think of some Grid tie 300W panels for about the same price and using a MPPT controller
