Can I use an uninterrupted power supply (UPS)to trick my grid tie inverter continue to work during power outage or off line? Will the inverter blowout my UPS?
Most Popular Topics
Use UPS with grid tie inverter during off grid
no it will not trick the grid tie into working.
If you somehow manage to get it to come on, then yes it will most likely over charge your batteries and have an unpleasant ending.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNH -
Simple a GT Inverter is a current source, and designed to pump power into a very low impedance of the grid. Its power must go somewhere, or die trying. You home wiring system and what is connected to it does not have a low enough impedance to satisfy the Inverter, and its voltage ewould spike indicating there is no Grid Available and shut down like it was designed to do.
MSEE, PEComment
Short answer - no.
Longer answer - you can do it if you use the right equipment. The right equipment is NOT a $99 UPS from Home Depot. It's a hybrid inverter that can handle AC coupling, like a Radian plus batteries plus a relay to prevent overcharge. You'd be looking at about $8000 for a system like that.Comment
