Announcement
No announcement yet.
Had my best performing day in 3 years...
  • Filter
  • Had my best performing day in 3 years...
    Only to see it was because of "production" taking place at night. Has anyone seen an issue like this before?
    7.2 kW / LG NeOn 2 300's / Enphase M250
  • #2
    It looks like a software problem to me. I keep track of daily and year-to-date production
    with this meter, no software involved. Bruce Roe
    • #3
      I want me some of those panels !! I'll use them with my daytime array !
      • #4
        And wait till the PoCo hears about this. Bruce
        • #5
          Sounds like you got some Lunar Panels mixed in your batch of Solar Panels.
          • #6
            Here is my snapshot of one day that it happened to me, seemed to be making up for day before that monitoring went down and was not reporting. At least from what I could tell.
            12/27/17 6:00AM 3.963kWh 0.662kWh/kW 1,621W 1,620W 0.271kW/kW 47.3F - - -
            12/27/17 5:55AM 3.828kWh 0.640kWh/kW 1,621W 1,620W 0.271kW/kW 47.5F - - -
            12/27/17 5:50AM 3.693kWh 0.617kWh/kW 1,621W 1,620W 0.271kW/kW 47.5F - - -
            12/27/17 5:45AM 3.558kWh 0.594kWh/kW 1,621W 1,620W 0.271kW/kW 47.5F - - -
            12/27/17 5:40AM 3.423kWh 0.572kWh/kW 1,621W 1,620W 0.271kW/kW 47.5F - - -
            12/27/17 5:35AM 3.288kWh 0.549kWh/kW 1,621W 1,620W 0.271kW/kW 47.7F - - -
            12/27/17 5:30AM 3.153kWh 0.527kWh/kW 1,621W 1,620W 0.271kW/kW 47.7F - - -
            12/27/17 5:25AM 3.018kWh 0.504kWh/kW 1,621W 1,620W 0.271kW/kW 47.7F - - -
            12/27/17 5:20AM 2.883kWh 0.482kWh/kW 1,621W 1,620W 0.271kW/kW 47.7F - - -
            12/27/17 5:15AM 2.748kWh 0.459kWh/kW 1,621W 1,620W 0.271kW/kW 47.8F - - -
            12/27/17 5:10AM 2.613kWh 0.437kWh/kW 1,621W 1,620W 0.271kW/kW 48.0F - - -
            12/27/17 5:05AM 2.478kWh 0.414kWh/kW 1,621W 1,620W 0.271kW/kW 48.0F - - -
            12/27/17 5:00AM 2.343kWh 0.391kWh/kW 1,621W 1,620W 0.271kW/kW 48.0F - - -
            12/27/17 4:55AM 2.208kWh 0.369kWh/kW 1,606W 1,608W 0.269kW/kW 48.0F - - -
            12/27/17 4:50AM 2.074kWh 0.347kWh/kW 1,567W 1,572W 0.263kW/kW 48.0F - - -
            12/27/17 4:45AM 1.943kWh 0.325kWh/kW 1,567W 1,572W 0.263kW/kW 47.7F - - -
            12/27/17 4:40AM 1.812kWh 0.303kWh/kW 1,567W 1,572W 0.263kW/kW 47.7F - - -
            12/27/17 4:35AM 1.681kWh 0.281kWh/kW 1,567W 1,572W 0.263kW/kW 47.7F - - -
            12/27/17 4:30AM 1.550kWh 0.259kWh/kW 1,567W 1,572W 0.263kW/kW 47.7F - - -
            12/27/17 4:25AM 1.419kWh 0.237kWh/kW 1,567W 1,572W 0.263kW/kW 47.8F - - -
            12/27/17 4:20AM 1.288kWh 0.215kWh/kW 1,567W 1,572W 0.263kW/kW 48.0F - - -
            12/27/17 4:15AM 1.157kWh 0.193kWh/kW 1,553W 1,548W 0.259kW/kW 48.2F - - -
            12/27/17 4:10AM 1.028kWh 0.172kWh/kW 1,497W 1,500W 0.251kW/kW 48.2F - - -
            12/27/17 4:05AM 0.903kWh 0.151kWh/kW 1,497W 1,500W 0.251kW/kW 48.2F - - -
            12/27/17 4:00AM 0.778kWh 0.130kWh/kW 1,497W 1,500W 0.251kW/kW 48.4F - - -
            12/27/17 3:55AM 0.653kWh 0.109kWh/kW 1,472W 1,476W 0.247kW/kW 48.4F - - -
            12/27/17 3:50AM 0.530kWh 0.089kWh/kW 1,421W 1,416W 0.237kW/kW 48.4F - - -
            12/27/17 3:45AM 0.412kWh 0.069kWh/kW 1,421W 1,416W 0.237kW/kW 48.6F - - -
            12/27/17 3:40AM 0.294kWh 0.049kWh/kW 1,359W 1,356W 0.227kW/kW 48.6F - - -
            12/27/17 3:35AM 0.181kWh 0.030kWh/kW 1,292W 1,296W 0.217kW/kW 48.7F - - -
            12/27/17 3:30AM 0.073kWh 0.012kWh/kW 880W 876W 0.146kW/kW 48.9F - - -
            12/27/17 3:25AM 0.000kWh 0.000kWh/kW 4W - - 49.1F
            Definitely no sun at those hours
            • #7
              This happened to me last night, when the Inverters shut off for the day my monitoring software said my system had produced 61.3 kWh for the day and this morning it says 63.5 kWh for yesterday . So I assume the Inverters shut off before another update came . I have had days when the monitoring was down for part of the day from wifi problems and the numbers were off and then the next day or two they were adjusted. Before I had monitoring software I would go out at night after the Inverters shut off and get my E total kWh's each day which is more accurate , I'm thinking of just running a hard line ( Ethernet cable ) to my router so I would have less problems with the glitchy wifi .
              9.36 grid tied, Phoenix Arizona
              • #8
                My first thought would be the clock on your inverter is wrong or has the wrong time zone.
